My 1992 R32 GTS-T had an AVO turboworld boost gauge installed in the drivers side vent (to the lower right of the steering wheel) when I bought it.
It has always been a bit useless as it doesn't light up during night driving.
Recently I realised it is much more accurate than the in dash boost gauge and decided I needed to get the backlight wired up (assuming it works) in anticipation of hooking up a turbotech boost controller.
After pulling off the lower drivers side dash panel and pulling the gauge out of the vent a bit I found a red wire and a black wire coming from each side of the gauge housing, the two red wires have been spliced together with another wire attached running to the headlight switch, the two black wires are also spliced together.
After taking off the dash surround with all the switches I could not find any point where the gauge may have been hooked up in the past and the wire connected to the two reds went no where.
Wondering what the easiest way to wire up the backlight to get it to turn on with the headlights, preferentially parkers but otherwise low beam/high beam.
Also has anyone heard of the brand AVO Turboworld before? Is it supposed to be decent?
The boost gauge is mechanical and is joined with a t piece to the stock gauge line.
Edited by Luke HCR32
https://www.sau.com.au/forums/topic/380566-wiring-aftermarket-boost-gauge/
Will that require me pulling out the head unit or the centre console surround? I have an aftermarket pioneer head unit.
I did notice one of the wires to my fog light switch had a bit of a nick in it (red and green one at top left of plug) could this have been the original source?
You dont need to put a additional fuse in. If youre going to short something and draw so much current, the original fuse for the headlight switch will blow. Sooooo.... theres already a fuse in the circuit. Just splice use the headunit wires.
You can even use the cigarette lighter wires! Shit you could even use youre odometer dash lights as youre source.
Black red. Easy peasy.
Edited by eat_me
make sure whatever you wire it to, it only lights up when the car is on or ACC is on.
some plp make the the mistake and wire it up so its on constantly (common issue with CD players) and they wonder why their batteries keep dying lol
Cheers guys, ended up hooking it up to that frayed fog light switch wire and fixing the wire at the same time, comes on when I turn the headlights to parker or on. Grounded it to the stud above the bonnet release.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
