hi i have a s1 stagea and am looking at having to get a new radiator.
so i would like to know if they are the same as r33/34 gtt or gtr?
i could get a after market 1 but not want 1 at the moment as i have other things to do.
so i ask because my mate is changing his r34 gtr 1 and might be able to grab his stock 1 for the moment
https://www.sau.com.au/forums/topic/380570-radiator/
i think the r33gtr radiator did fit, there was a thread just before this somewhere asking the same question, try searching for it.
but in regards to the r34 radiator, i wouldnt know, i always thought they were thicker than the other skylines.
dont quote me on that tho.
https://www.sau.com.au/forums/topic/380570-radiator/#findComment-6068034
r33 gtst
you can also get them with the auto trans coolers still in them
about $200 from the ebay, mine is a koyorad branded one
http://www.ebay.com.au/itm/110712146710?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_1998wt_1141
thats the one i got, but its for a manual
https://www.sau.com.au/forums/topic/380570-radiator/#findComment-6068256
ok i think its leaking at the top. i not shore but think its where the tank meets the core.
i am using my mates cap to see if it coming from there but i dont think it is
You can get the tank off and refitted. Cheaper than another rad
https://www.sau.com.au/forums/topic/380570-radiator/#findComment-6069571
i think i was looking at $170 for a new top tank + rod the core and clean it out
my top tank was split under the filler hole
or get a brand new rad for $200ish (i went the hard way and wasted $350ish on a justjap alloy rad, it was leaking after 18 months)
https://www.sau.com.au/forums/topic/380570-radiator/#findComment-6069694
