hey all, just did a turbo swap on my stagea, stagea Neo OP6 turbo swap with a R34 NEO OP6 turbo.
the r34 turbo has a plasic feeling front wheel (it is also black in colour), also has a flex in it when pushed. was guessing thats the case since people say the front is plastic and rear is ceramic.
now my stagea had a different front compressor wheel. My guess its a alloy wheel as it isnt attracted to my magnet. its heavier and also has no flex in it
so im just trying to research if there was a different front wheel used in the stagea compared to a r34, or possibly if they had a revision of turbos through series 1 and 2 of the R34 skylines......
i dont know what year model the r34 turbo came out of, but my stagea is a 2001 build
so does anyone have pictures of their stagea's turbos?? plastic or metal wheel??? or any info at all??
also as a last note, my turbo is stock, not high flowed.
Maybe post up a pick of your turbo. Does it have any other markings. How many blades does it have and are they twin or single blades?
Mine was just the normal nylon/plastic comp wheel with the ceramic turbine. I have a 99 model.
looks like the same style as the steel wheel compressors in the early model R33's before they changed to the nylon/plastic ones. i remember reading that one of the series's of the R34's had a steel wheel compressor, maybe the Stagea did too.
just found it. check out this link
http://www.skylinesaustralia.com/forums/topic/69089-differences-between-r34-and-r33-turbo/page__view__findpost__p__1527454
aaah, indeed. well i guess it isnt steel. steel is attracted to magnets right? so alloy? also i didnt know there were 3 series cars. always thought that both r33 and r34 both only had 2 series each. i will see into this some more. also my nylon plastic turbo has twin blades on the front, just like the alloy one
Yeah the nylon ones do have a second fin but it's not as prominent as the steel ones, you can't really notice it looking down the compressor inlet.
Yes it will be some kind of alloy, I don't know what though. It all depends on the steel as to weather its magnetic or not ie stainless steel isn't magnetic.
I don't think the stagea followed the R34 and had a 3rd series, it's just an R34 thing. Apart from the garret turbo I know the fuel/ign mapping is different on the S3 R34's, I've compared the base maps of the R34s supplied with nistune.
Edited by QWK32
really, r34 had 3 series? wow, but they had a short lifespan, 98-01 right? so one year per series nearly. all i know my compressor housing says 45v3 so makes sense. wonder what the power difference was between the 3 series's, turbo lag and fuel consumption.
here are some pictures, i dont know what those random marks on the rear of it are though
The marks are where material has been removed to balance the impeller.
There is nothing per se wrong with a composite material impeller; it's cheap to manufacture, nice & light, which would aid response, and it's unlikely to destroy the housing or the engine if the centre bearing fails.
The only time it might be an issue, would be if you were to grossly overspeed the assembly, but I'd expect the ceramic exhaust turbine would fail first.
when i had my turbo out it had a black compressor wheel
pretty sure thats the nylon front wheel that all s2's and r34's should have
yours have have had a turbo swap at some point in its life
yeah, i havnt had a turbo swap on my car, 100% sure on that, that thing was sooo rusted into the manifold, sure it was stock.
im guessing that 2000 onwards or late 2000 models had a steel wheel. I was pretty surprised when i found out should have swapped front wheels on the turbo, now im scared that plastic thing is gonna blow off. im running 13psi, might need to turn down now.
Should be alright, I ran mine stocker on 13psi, although only for about 6months until I upgraded it. I also ran a plastic wheeled R33 turbo at 14psi on my R32 for years without it failing.
I'll have a look on Nissan fast later and see what turbo part numbers I can find. But I reakon they followed the r34 and went to steel wheel in the late models.
had a look in Nissan Fast
it lists 14411-AA100, the plastic wheel one, on all stagea's 08/98 and up. so all S2's. it does however list the 14411-AA110, the steel wheel one, as an alternative part number.
also a bit of useless info, in my version of fast it lists a replacement turbo at ¥120000 = $1516.
so i wonder how the steel wheels managed to get stuck on the stagea????? maybe had some extra steel wheels floating around and nissan said lets just throw em on random turbos.... bahaha
id rather buy a garrett turbo than spend fkn 1500 on a stock new one......
probably popped when it was newish in japan => warranty replacement or somesuch
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
