R32 CAS - $60
R32 Ignitor - $70
R32 GTR front and rear brake lines - $80
R32 GTR castor rods with offset bushes - $50
R32 radiator rubber strip - $20
R32 ignition barrel key trim - $5
R32 rear ash tray - $10
R32 headlight rubber boot - $5
R32 mirror sill - $5
R32 door locks - $40
R33 GTR floor mats (5 pc) - $100
R32 sills (pair) - $15
R32 drivers side A pillar - $30
R32 Greddy A pillar holder (single, edges not straight) - $20
Dirtgarage 2wd / 4wd switch - $50
R32 passenger tail light cover (single black) - $20
Dimple neodymium magnetic sump plug - $30
R32 drivers seatbelt guide - $20
AMR R32 GTR 300km cluster (early model) - $200
R32 std cluster (unknown condition, good for parts, late model) - $30
Apexi EL2 Control Box - $50
Apexi EL2 white gauge (electronic, comes with wiring loom but doesnt light up at night) - $60
GReddy boost sensor (comes with wiring) - $30
R32 GTR wing (appears to be fibreglass 1:1 copy, some cracks in the paint) - $70
R32 GTR bootlid (has a small bent edge below the badge) - $70
R32 steering wheel angle sensor - $40
R32 centre console - $30
Kumho KU31 255x40x17 tyres (5000kms old) - $400
postage at buyers expense, pickup welcome (pendle hills, western syd)
th_71188918.jpgth_e226fab7.jpgth_7070b2f2.jpgth_fcf1438a.jpgth_d89ad406.jpgth_710835d2.jpgth_e4cbe059.jpgth_6febd2eb.jpgth_f9e054ce.jpgth_5ea8d59b.jpgth_3572307b.jpgth_ba270dc5.jpg
https://www.sau.com.au/forums/topic/381043-bits-n-bobs-sale/
  • 4 weeks later...
  • 1 month later...
R32 CAS - $60
R32 Ignitor - $70
2 x Kumho KU31 255x40x17 tyres (5000kms old) - $200
  • 1 month later...
R32 CAS - $60
R32 Ignitor - $70
Kumho KU31 255x40x17 tyres (5000kms old) - $200 (pair)
  • 1 month later...
R32 CAS - $50
R32 Ignitor - $70
R32 CAS - $50
R32 Ignitor - $70
Edited by BWRGTR
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
