drag radials!!!! and suspension
are you taking raised suspension to fit drag radials under the car, or lowered suspension? stock suspension is better for drag racing than a set of coil overs.
WTF are you smoking?
Your reaction time is the time it takes from when the green light lights up, and when you break the first beam.
Your reaction time, is all about how QUICKLY you react to the green coming on. If you had come to the SAU NSW drag day we held not long back, Sydney Dragway officials even explained this.
What can quite majorly effect your ET is your 60 Foot time. This is the time it takes for you to travel the first 60 feet of the track. 0.1 of a saving here can be 0.2 of a saving at the top end of the track.
For your ET, your reaction time means NOTHING.
baaaaaaaaaaaaaaaaaaaaaaaaaaahahahahahahaha, you might want to read some of the earlier posts in the thread next time to stop yourself looking silly.
Edit:
NVM... I thought he quoted Zebra and was arguing...
silly.
No raised suspension..ye NEW standard stuff is better than circuit coil overs...but anyone semi serious about it doesnt have standard springs and shocks in the back
Previous launch was a 4100RPM drop, this time i'm thinking release the clutch before the friction point while giving gas just before the car starts to move(hand brake or something to stop it from going forward) then slipping (or trying to :P) the clutch out? I'm all for suggestions guys.
if you weren't loading the car up on the handbrake last time then definitely do it next time. doesn't do the clutch much good but it will give you the best launch. test it out tomorrow on the road and you will notice the difference.
Tried it today, soon as the clutch is fully released it still chirps a few times but not as bad as before. Took off a fair whack faster though, kinda like stalling an Auto up.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
