Car: '93 R33 GTS S1 RB25DE
Okay I've finally got my consult cabled hooked up to my car and the laptop running. First thing I done was read error codes to find that apparently my knock sensor is faulty. Though there are no signs of the knock sensor playing up at all (idling @ 675rpm, normal performance)
I just ended up clearing the fault code but it kept coming up, I ignored it.
Couple of nights ago I started the car (prior use was 2hrs before), took off up the street, at the stop sign the car starts revving 675-1500 by itself (faulty knock sensor?)
After I took off it stopped and I haven't seen the problem since. No fault error codes any more.
Is there any possible way of testing the car to see if it's really faulty or not?
My muffler and one of my hotdogs recently needed to be replaced, so I ended up with a cannon and a used hotdog. But I want more out of my exhaust. Many have told me go for a 3" straight pipe all the way through.
Any other suggestions?
I also need a good place to get my car serviced and what not due to rego coming up soon, is there any good places around the Macarthur area?
Thanks :P
A 3" pipe for a NA RB25 is too big.
I have a consult and a cable for the laptop aswell and they are ok but it is no where near accurate as the real thing and i usually read the screen and have to find the fault myself.
It could be the knock sensor,O2 sensor or the throttle position sensor broken or just not set right or lots more. All these things can set the engine to go into a 'MAP mode' which cause the usual 1500rpm everyone gets when something stuffs up.
Had the same problem it ended up being my timing was at 21 deg static and it was causing the fault
ajusted it back to 15 deg fault has never come back,
Thanks :P
Yeah forget it, this is what my car (is it even mine any more?) looks like:
http://img440.imageshack.us/img440/4977/07112011102.jpg
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
