Hi Guys,
I don't think i need a story trying to sell these rims, we at OTR know how popular the Black wheels are and their waiting times when ordering. We have saved all the headaches and produced these with Rays to make them available shortly, get in quick as the first set sold before it even landed..now we have shipped the balance of them..
Available in
Only one set 19x9.5+22 $4000
Only one set 19x10.5+22 $4100
A few sets 18x9.5+22 $3700
TE37SL FLAT BLACK
LIMITED EDITION OMORI LMGT4
Available only in 18x9.5+12 $4000
https://www.sau.com.au/forums/topic/381536-black-te37-sl-lmgt4/
Yes I believe the Z-tune had a unique +5 offset (but the same 18" x 9.5" dimensions otherwise)?
Can't read the Japanese from OTR's original post so don't know if it's promoting the actual Z-tune, or using the Z-tune to promote these (very similar) Omori special edition LMGT4s.
We are promoting the Omori Edition and not the Z-tune. This Edition was made by Rays for Omori factory and we were lucky enough to score a few sets of their production run. I hope that clears everyhting :thumbsup:
Cheers
Ken
  • 3 weeks later...
  • 3 weeks later...
  • 3 months later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
