  • Replies 67
hrmm ok cheers the car it came from was a 93 so the duel blades means its been changed at some point so im not 100% sure what it is haha i will take a pic soon but was same as this...
greddy gauges SOLD from my other thread
ok just got our quote back for driveway and need to come up with a bit more coin QUICK so we can get it done before christmas!!!
Turbo $250
Headlights $250
Full 3" turbo back exhaust $300 with free kakimoto rear section so you can choose how loud you want :P
$400 for the 18" mags
$200 for Front and rear seats, door trims and rear trims.
$30 fuel pump
$40 Fuel Tank
$200 Stock struts
Stock suspension arms $make offers
$30 for door windows or $50 the pair
window elec reg/bits in the doors $20 each
clutch/brake/accel pedals $60 the set
complete Hicas setup $80
heaps of other bits here just pm or MSG 0417080960 if interested
ok guys the shell is hopefully going tomorrow i will be taking a bit more off the car then she will be GONE if theres some little bits you need let me know ASAP otherwise it will be gone :P
i still have turbo (conrimed supertight series 2 twin blade comp wheel and nylon exhaust)/headlights/bott with GTR stlye wing, all stock suspension.
pics of wheels need a clean bit of rash but better then stockies :P tyres need replacing $400
Stock suspension dont see any leaks dust covers are rooted but good to have as spares if ya get done by the po po $150 for the set
Stock castor rods $40 pair
TURBO STILL FOR SALE!!
the shell should be going this week so if ya need something let me know asap!
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
