Its called a sidewall, smart people get tyres to suit the driving conditions, they look good for the street where pot holes and rough roads will make having lower profile tyres a PITA, me, I wont go any lower than 40 series even on a 265 for the street or the track. currently running 245/45 17 on the street myself and they are awesome on the road and good enough to do 12.2 at the drags.
Whilst I do admit low profile tyres can look good they are a PITA unless you always drive on fresh smooth blacktop, or if you dont mind the harsh ride and damaged rims.
I agree hank :yes:, shouldve gone 235 haha. I suppose at some point you have to choose whether you want looks or handling,
there cant really be both to a certain extent. As long as i can make it look tough im happy.
Edited by arsnic_apple
:huh:
But 235/40 and 265/35 have the same height sidewall...
I stand corrected, I still like more side wall though, 93mm for the 265/35 or 106mm for the 265/40, I would go the 40 as a minimum. As for 235/35 at 82mm or 235/40 at 94 mm, for the street that extra 12mm comes in handy
But yes, IM WRONG, sorry for causing any missinformation.
:domokun:
Alrighty got rear guards rolled today and rims and tyres are now on. The look is growing on me, its more of a tough race sorta look which i
do not mind at all. I had a look at the coilovers while i had the wheels off and they rears were already wound all the way down and i only had
about an inch to play with at the front. Teins and there poor adjustability :glare:. Lowered the front slightly and it doesnt sit too bad. Once i get
the camber and everything done it should look sick. No problems at all fitting the rears inside the guard, seems to be enough room. I havent
gona around any corners or anything fast yet so i shall find out maybe tommorrow. Ill also get photos up tommorrow for those who would like
to have a look.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
