Abandoning the dream of building my low mount monster so these have to go
Hypertune single 102mm throttle body and plenum new $1500
six boost steam pipe low mount manifolds with ic pipe $500 used
sard 1000cc injectors used less than 10k $500
rb26 head with valves no cams will come with rocker and timing belt covers suit recond $400
monster twin entry cooler twin 60mm inlet 100mm outlet 140mm core has arc badge but cant be certain $1000
HKS GT RS turbos unknown kms but minimal shaft play one has a broken stud $1500
rb26 engine loom $100
Injector plate $100
Nismo afms used $500
hicas lock bar new $80
ARP headstuds for RB26 new but have been out of the plastic $250
Pm or 0411196595 cheers Scott ,located in Adelaide
post-45347-0-69426900-1320129336_thumb.jpgpost-45347-0-45777100-1320129363_thumb.jpgpost-45347-0-79875400-1320129399_thumb.jpg
post-45347-0-87729700-1320129427_thumb.jpgpost-45347-0-80445300-1320129453_thumb.jpgpost-45347-0-43977500-1320129504_thumb.jpg
Edited by scotty32
https://www.sau.com.au/forums/topic/381771-rb26-performance-parts/
Can the injectors be used with a fairly stock ecu? Im planning on a power fc in the near future, but am running a standard ecu that claims to have been remapped by HKS Kansai ( no speed cut, boost cut or rev limiter etc). If so, where abouts are you? Whats freight worth to ballarat, victoria? PM me back when you find out, cheers
Edited by JDMGTR17
I wouldnt suggest running them with a stock ecu
