Hey hows it going i got a R33 Series 2 which can not start, it cranks over but it wont start, it aint sputtering so it wouldnt be a fuel issue, but im thinking it could be down to the spark. The car originally had broken down while driving so i had to get it towed back home. The things i have currently done to the car is a ecu diagnostics check and it came up with 55 so everything is fine according to the ecu. I also chectked the spark plugs and did notice a very small amount of oil on the spark plug i only removed the first 3 spark plugs.
I did check the cables of the distrubator and everything seems fine, i However recently hit a pot hole and had probably caused to dislodge a gasket or something and its been losing a bit of oil latetly which has caused the oil level to go down and has caused a very noticeable amount of oil on the left side of the engine just under the turbo, so im not sure if this has anything to do with it. I also have also started to experience a bit of oil in the inlet system more then i used to, infect i used to not experience any oil.
The main thing i want to know is there any tips were you can guide me what i should do next to see if i can resolve the problem, or a possible sympton that usually causes problems like mine as i have had done a search on the forums and couldn't find anything.
Yours Truly,
Nick
https://www.sau.com.au/forums/topic/381846-r33-not-starting/
Hi i would be checking the turbo feed line incase it might be cracked or the oil return lines to the sump from the turbo and cylinder head
also check rocker cover bolts.There is not much else there unless you have damaged your sump remove the heat sheilds over your tubo
and it should give you a better inspection.
With your engine not firing it could still be your fuel pump or your crank angle sensor check to see if your fuel line pressurises then the ignition
is switched on and that you also hear the pump prime up.
Ive done the fuel check on the pump and i can hear it prime and ive taken the fuel hose off and gave it a crank and fuel started coming it out. I took of the crank angle sensor and turned the wheel and could hear the injectors going so id say its not that as well.
How would i go by checking the spark and coil packs to know if the problem is a spark related issue?
Pull a coilpack out of the bracket. Plug it in to the loom. Fit a spark plug to the coilpack. Rest the hex of the spark plug against an earth (something metal) and crank. See if the spark plug has a strong arc.
Can u explain more.
Did it stall and now won't start? If so what exactly happened when it stalled?
When it stalled it happened when i engaged the clutch so i thought it would it start up when i disengage it, but it didnt. So i tried cranking it and it kept turning over but it didnt sound like it was spluttering so i was thinking it would be spluttering if it was fuel, if it wasn't most likely something like a ignition or spark problem.
The spark plugs it currently has a brand new Bosch Iridium ones which are gapped at 1.0mm they been working perfectly fine so far i did however check the and they look perfectly fine for something thats been in the car for the past 300ks.
I am however getting a set of coil packs for a series 2 this week and possibly going to change them over to see if its down to the coil packs.
I will try today the spark plug problem and give it a show if its down to the spark
Okay i got the car started i changed the ecu over, however the car now is running quite rich it blows black smoke, i however am having a very rough idle issue it sounds like a really lumpy 69 camero but it sounds like its struggling to stay on and its reving at about 800 rpm, i also get this ticking sound from the turbo and exhaust manifold area.
Would you possibly know what the cause of this could be, im guessing it could be a fuel relay. However i did check the injectors and the only one didnt seem to change in idle was first injector not sure which one it is but its the first one when looking from the front.
However all the others changed when i took the plug out except for that one.
How long did you run it for could be a build up of fuel in the cylinders correct me if I'm wrong. Ticking sound could be a small exhaust leak check to see if all the studs are still there and gaskets are in good condition
I ran it for a good 10minuets, ill reset the fuel pump tomorrow and ill also check the leak i think it could be i need some new studs, as i recently replaced the exhaust gasket. Though the rough idle im sort of worried about it, its quite rough its i got to admit, its a strong vibration, like it would sound awesome in a muscle car not so cool in an import
Okay car aint running rough any more i replaced the exhaust manifold head studs as i saw a bit of carbon build up so ive replaced them however i took the car out for a short drive today and its back firing real bad and its struggling to boost up, however it broke down after 5 minuets again same problem it wont crank over, would you guys were i could check next.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
