hey all, just wanted to ask any guys with 31's whats involved with putting a 20 or 25 into a 31? looking at a cheap 2l pintara wagon and rough cost for putting in a 20 or 25 with auto box.
rather put in this section for a quick reply. wondering if it could be done for around the 4K mark not including the car.
cheers
matt
https://www.sau.com.au/forums/topic/381998-pick-peoples-brain/
cheers
matt
While I never swapped an engine in my old r31, I did have the misfortune to have the torque converter die... was cheaper to get it converted to manual, so naturally I did that. I think the parts were around $650 which came with the pedals and xfercase and clutch, and around $650 labor to fit.. this was back in 2003 so I don't know if the parts/labor would be cheaper/more expensive but I'm guessing if you got the engine + box you'd save a bit. That said the sr20 is probably cheaper and lighter and they give a decent amount of power and are pretty darn strong... also you'd have to factor in getting bigger brakes and getting it engineered. Dark.Sky put a rb25det into his 32 which originally had the rb20det and he had to do the above so you can guess that there is probably a little bit more involved for you...
-D
gonna struggle doin that on a pintara matt
even tho the r31 platform is different, the trans tunnel on the manual is narrower
*edit* - read that you're goin to do it with an auto, thats not so bad
if its pintara, you'll just need skyline crossmember and some RB30 engine mounts (as the RB20 / RB25 ones push it too far forward and fan chews out the back of the radiator)
if you can find a skyline to put it into, piece of cake. swap RB30 engine mounts off and onto the new motor, run loom, think theres like 5 wires to get it to basically power up (theres a wiki section on R31SC with this info from memory). If you score an S3, the auto is the same as 20DET and 25DET auto boxes (4sp electronic auto)
haha thats what i was thinking matt. found a one owner pintara with only 120000 ks on it. its got the 2l auto and only wants $1200 for it.
yeah adam something to put the dogs in the back. dont think i could handle the stock 2L though
tonnes of gxe , silo, and TI s3 r31 for 500-1000 bucks in vic country area. in good nick too just out of rego- RWC
ebay is full of them
rb20det one too but he wants a bit much for it
I tried to buy a nice one in dinga the other day but someone was test driving it while the guy was on the phone to me, kid bought it. grrrrrrrrrr
yeah more than i have to spend though:( only have a budget of 5K at this stage
If 5k total is your budget, I'd definately follow the above advice and just buy a 31 with all the bits and pieces (one with an rb30 will do) - Can probably get a Silhouette for that money in decent nick - good cars
-D
-D
nah has to be a wagon so silo is out. thinking maybe a patrol with the rb30 in and doing some mods on one of them
... or just get an R31 Wagon... the GXE's are pretty darn good as a platform to start with... I don't argue with your choice but the r31 platform is robust and is good for many applications - just need to be patient and get the right one
Good luck! I reckon for $5k you'll get an excellent skyline
-D
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
