set of 2"/52mm gauges (brand new, never used) set x 5
white set of 2"/52mm gauges (brand new, never used)52mm TYPE R performance gauge set0-100psi oil pressure meterboost 0-30 in.hg to 0-20 psi meteroil temp 2"/52mm gauge meterwater temp 2"/52mm gauge metervolt measure 2"52mm gauge meterall 5 gauges brand new in boxall 5 gauges come with accessories etcall 5 gauges are electricalmounting bracket, english instructionshigh quality products
2"/52mm "DRIFT" boost gauge brand new never used
$50
WRECKING HR31
ALL PICTURES ARE AT THIS LINK>>> <a rel="nofollow" href="http://s149.photobucket.com/albums/s44/luker_1987/HR31%20PARTS/" target="_blank">http://s149.photobucket.com/albums/s44/luk...7/HR31%20PARTS/</a>
Hr31 drive shafts / axles inner & otters $400
R31 hot plates good condition $80
52mm alloy radiator suits rb $80
Ba/au twin thermo fans $55 + 12" inch thermo fan $30 + twin thermo 10" inch "from memory?" $30
Hr31 complete rear brake set up $70
Hr31 rear struts & lowered springs $50
Hr31 doors x 4 >>NOW PARTING<< electric windows, switches, glass, door handles (chrome) door cards sold
Hr31 guards (driver & passenger sides) $80 each x 2 sets (gun metal grey or silver) one silver drivers doors sold
Hr31 rear bumper trim says "skyline" on it $50
Hr31 or R32 side mount intercooler $50
Hr31 seat belt covers (driver & passenger) $45 & rear quarter glass interior covers $50
Hr31 door rubbers (seal the doors) $50
Hr31 rear quarter glass surrounds says "skyline" on them (not the sticker type) $80
Hr31 complete seat belts (front & rear) $50
Hr31 floor carpet full (front & rear) $100
Hr31 roof lining $40
Hr31 dash $50
Hr31 blinker/turn signal lever & wiper levers, headlight/high beam levers $40 each
Hr31 dash buttons (random bunch, let me know what you need)
Hr31 dash clock & other dash parts available
CAN USE AUST POST OR COURIER MOST ITEMS (AT YOUR COST) I'M LOCATED IN COOMERA (GOLD COAST) PICK UP FROM THERE CHEERS LUKE
  • Replies 87
    • How do you propose I cable tie this: To something securely? Is it really just a case of finding a couple of holes and ziptying it there so it never goes flying or starts dangling around, more or less? Then run a 1/8 BSP Female to [hose adapter of choice?/AN?] and then the opposing fitting at the bush-into-oil-block end? being the hose-into-realistically likely a 1/8 BSP male) Is this going to provide any real benefit over using a stainless/steel 1/4 to 1/8 BSP reducing bush?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
