I supplied mine for $50.30 delivered to me for 2 sets, plus $12 delivered express from me to interstate guys.
So I take it the cambers arms from that guy are a no go?
Edited by slippylotion
  • Replies 130
Story number 47 is that the ones that actually fit are toe/traction arms that can adjust a little bit of camber. I'm guessing he isn't talking camber he's talking toe, so figured I'll order these and if he doesn't stop stuffing me around just ask for a refund.
Bump.
I'll give it until Friday for people interested in the SPC bolts to let me know, then I'll start getting money sorted.
So far I've got:
Me x 2
Jase x 2
Mike x 2
Bolts are these: http://www.spcalignment.com/component/spc/?task=part_description&pid=72265&region=AsiAust&make=Nissan&model=370Z&year=2009+-+2011&from=AsiAustFrom&to=AsiAustTo
You need one set for camber, and one set for toe.
They're $US48.82 per set, excluding delivery. Just waiting on an email back regarding freight price.
I have sent you a PM, but the web site you linked to is showing $48.82. I've also contacted SPC to see what the go is on their end.
I don't want to pay more than I have to, so why do you think the site is showing double the price?
Great, thats very helpful.
I'll have a look around and see what I can find. I did PM you to ask for more info, so if you feel like passing that site on that'd be great.
No, that was helpful. Explains why you were getting them cheaper. I was under the impression you got them direct from SPC.
I've found a couple of different places cheaper, but I'm waiting from a response from SPC too, sometimes lower freight costs evens it out.
This is where you can get them cheaper guys. He will send up to 20 sets for the $50 postage fee.
http://www.ebay.com.au/itm/SPC-Performance-Rear-Camber-Toe-G35-G37-M35-M45-370Z-/140476842848
Cheers
Bargain! Thanks Paul. Did you check out any Aus suppliers? The email I got back from SPC listed two that I think might be worth chasing up, at least for curiosity's sake.
Update as of today:
Me x 2
Jase x 2
Mike x 2
Albs x 2
Still finalising price, but it'll be about $50 each plus postage for those outside of SA max, if I go through Paul's supplier.
Update as of today:
Me x 2
Jase x 2
Mike x 2
Albs x 2
ill be in for both sets.
PM aent
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
