Heya guys as the title suggests my AWD controller for my gts4 has had it. The wiring itself is fine just the little box which you set the AWD settings at. I opened it up for inspection and a capacitor has dropped its guts everywhere. (im assuming thats why the backlight always flickered and now just is not going anything). Anyways fixing it i believe is not possible as the capacitor acid is as hard as a rock. but from what i could see only four wires plugged into that controller. If say i bought a resistor, switch, and a few other little things do you think it would be possible to make ? i really liked this controller as it had the option to keep the stock attessa or have complete rwd or 4wd etc. if not s there any other good units out there ?
https://www.sau.com.au/forums/topic/382701-my-grid-ts-dancer-has-pooped-itself/
There are few places that make these any more, even grid I think don't now days.
The 2 choices I know of are Mountainrunner on these forums from QLD (he makes an excellent unit, lots of options, display, and excellent local support), or a mob on ebay that put $20 of components in a box and charge $200 for it (this also works pretty well, just missing the fine adustment).
Either will be miles better than stock in an r32
I found it excellent...particularly becaues Raceworx is my race team :thumbsup:
I didn't mention that because it has been out of production for years. But if you can find on around, grab it. They do come up second hand.
They were priced a little above the ebay ones but were much more controlable. Once they were out of production Mountainrunner's ones became the best option from my point of view because they have the same or more control as the Raceworx ones did. They are just a little more expensive, but still very cheap for the performance you gain.
haha good score, there can't be many of them left around!
In street use you won't notice too much (unless you drive like me all the time). I'm sure 4 is fine
On the track, 4-6 depending on what you prefer, your tyres and wheel alignment and how healthy your attessa system is. 10 if it is wet and you aren't running more than about 20min at a time
0 if you like skids everynow and then.
Cheers for the advice guys, i will try cleaning first maybe even take it to a pro to have a look, what is my cheapest alternative ? I want to have 50/50 awd, keep the attessa system and be able to have full rwd will the shoddy ebay one do the trick ?
yeah ebay one should be fine (as would a 2c resistor if you had the time to stuff around and find the right one). basically these controllers just reduce the output from the lateral g sensor which causes the computer to think the car is in a straight line, therefore applying more power to the front.
Duncan: do u still have instruction manual handy? I'm currently doing the wiring to the radio control switch, manual advises cutting orange, silver and middle black wires of the switch
Controller end has four wires, white, green, blue and black
Connect the white wire from the controller to orange wire, blue wire on controller to black wire and the green wire (instructions stop here)
Now I would assume to connect green wire to the last remaining wire (silver), so when operating, pressing up increases adjustment and down vice-versa
When I hold up button for 3 secs, my abs light comes on, I thought this would happen if I held the down button as it would turn off all front drive
Is my wiring connected wrong?
yep that ain't working right....I've linked 2 versions of the full manual with different wire colours. ABS and 4wd light should come on when you hold "down" 3 seconds.
http://www.hgeconsulting.com.au/attesa32-33.pdf
http://www.hgeconsulting.com.au/attessa_last.pdf
one thing to try if it is misbehaving....hold the up button while starting the car and it will reset the internal memory. Sometimes this clears some wierd errors.
wire colours did change over the years and I haven't done one for ages. Send me a pm if you are still stuck I can drop by and give you a hand sorting it out.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
