dammn that looks sexy. Too bad i only have 16k to spend :(
Price is nego :P
love the CF knee pad! :thumbsup:
xD
You selling this beauty? Oh noo.....
Yeahh... there are other more important things in life :P
Gonna be sad to see her go though, as I spent lots of money to stylist her to exactly what I want :(
@ Comsic Gate - It's got 12x,xxxkm on there now, soon I'll be going to Chequered Tuning to put a NIStune in to get it to 200kw at the wheels :)
@ suwidji - Yeah 16k is fine, but I'll rip a few bits out :P
  • 4 weeks later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
