Hey Guys, this might not be helpful at all but my car does this too and today i tried something different. I didnt let the fuel pump prime and the car started fine.
May have been a slight studder but way better than usual, but my car is stock so don't know if it helps. No mods stock ECU.
Could have just been a fluke but might be worth a shot and it backs what DVS is saying about it being too rich (too much fuel at startup). The Fix who knows lol
Same, the less i prime the pump the better it starts. If i prime it 2-3 times its like a f#ckin steam train. Just chugs and then stalls.
Yeah Sarge, i always get different out comes from it but the best is just starting it as fast as you can. I really think its to do with fuel but i have almost everything new on my car ... only thing is injectors i got them with low KM but im worried they are leaking but you also have changed your so hmmmm
  • Replies 44
just thought id put my 2 cents in ive got a r33 gtst 4 door and ive got the same problems as all u guys my car got high flow turbo, exhaust, fmic, and bosch fuel pump. Its still running stock ecu and stock injectors ive just replaced the spark plugs ive also got bigger injectors to go in it im wondering if i put in the bigger injectors am i able to get the stock ecu tuned or do i have to get an aftermarket 1
Nistune can run any basemap you want, in your case a Z32 or RB20 ecu with Nistune daughterboard inside can load a R33 RB25 basemap. Both these ECUs are direct fit, just that Z32 one has VCT control and the RB20 one doesn't.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
