Its not the fact the car is sitting on a slope...nope not at all
LOL, true, but then the kids wouldnt have anything to whinge about, somebody call a WHHHAAAAAMBULANCE.
In my opinion it just needs some 20mm spacers.
Cops are tops, are you going in to stop the 7 foot hillbilly from smacking his kids, no, then harden the puck up and post something usefull.
Haters gotta hate, I love haters, they make me LOL.
Book em Danno
https://www.sau.com.au/forums/topic/383126-cop-car-too-low/#findComment-6111247
Slope? Follow this link bud, you need it http://www.opsm.com....CFapS4god3wQLGg
WTF, are you blind, what is the weeds growing in, its called a drain, the road slopes towards it, you just posted a link you may need to use.
https://www.sau.com.au/forums/topic/383126-cop-car-too-low/#findComment-6111251
Yep, exactly that. Car is on a slope.
Also people need to actually READ up on the 100mm law. It's 100mm on in certain points depending on the wheelbase of the car etc.
Pointless thread is pointless
https://www.sau.com.au/forums/topic/383126-cop-car-too-low/#findComment-6111268
Guest
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
