  • Replies 158
Posted Images
I do mate, but it's a little bent. It's not bad though - you could probably bend it back into shape. You can have it for free.
You can have the bonnet for free too :) And the driver's side front guard :)
your a good bloke frank, Ill take it!!!
Ill even take away the crash and bash bonnet and front guard and stick em in my bin.
whats you number again, sorry
email it to me if you dont want to share: [email protected]
Update to the list of stuff -
Lower dash trim - $40
Door cards $30 each - passenger door card has a tear near the mirror - easily fixed
Mirror triangle cover thing - $20
centre vent - $80
driver's side round vent - $40
dash in good condition some very small bubbles (didn't notice until i found out these things bubbled up) $100
centre console storage thing between the seats $20
centre console surround that the storage thing connects to $20
rear quarter trim $20 each
rear wiper motor and arm $40
passenger door with window and motor (minus door card and mirror) $60
dash cluster (218,635kms) $30
dash cluster surround (missing headlight switch) $40
indicator stalk $40
A pillar trims $20 each
entire boot trim - don't have the cover for the wheel arches $40
glovebox $50
sun visors $20 both
rear vision mirror $20
door seals - driver's side has one crack in it, passenger side perfect $60 both
Mirrors - $40 each
front windscreen (has small chip - been there for years, no probs) $100
rear windscreen $200
passenger side quarter window $60
tail lights $40 each
rear bar $40 - has one dint and one scratch
passenger side front guard (has slight bend) $20
Passenger front guard (bit bent) - $20
driver's front guard (rooted from accident) - free!
bonnet (rooted from accident) - free!
kick panels - $10 each
brakes - all 4 calipers, rotors etc and hand brake assembly $600
brake booster $40
3" catback exhaust $100
stock dump pipe to cat including sensors $40
rb20det $offer!!
starter motor $50
Pod filter $20
AFM $100
hicas rack $40
fuel tank $100
fuel pump $30
Interior carpet $50 - has a tear in the driver's side (probably easy to fix), otherwise perfect
Centre dome light cover
Centre dome light (without cover)
front reading lights $15
roof lining $30
stock crossover pipe including BOV $40
Stock rb20det side mount intercooler $30
rb20 power steering reservoir cap
rb20 power steering reservoir (minus cap) $15
A/C compressor $50
Climate control panel $60 - not sure if the lights in it work
bonnet hinges $20
boot hinges $20
front seats - $50 each no tears but a couple of cigarette burns in driver's seat and the magazine holder in the driver's seat needs stiching at the bottom
rear seat
front windscreen wiper motor $40
front wiper arms $20 for both
HICAS computer $30
Washer bottle $20
steering column $40
alternator $10 (not sure of condition - i think a bit of battery acid spilt onto it or some crap, doesn't turn easily)
rear pods $70 pair
Stock manual ECU $80
hazards/tune/wiper switch (headlight switch already gone) $20 each
clutch+gearbox etc for manual conversion (still have flywheel)
passenger seat belt
interior mats
6 x injectors
Trim around the steering column
Turbo
Power Steering Rack
Stock coils
Ignitor
Driver's side door (just the door itself and window/motor mechanism)
Passenger side vent
Headlight switch
centre console tray holder thing
fuel pump cradle. Still have fuel pump
front seat buckles
ash tray
front fuse box fuses/relays/whatever
driver's side window control
diff
b/c pillars
locks/keys, brake master cylinder and 3 brake lines connecting to it.
Driver's side rear quarter window
inside passenger door mirror cover.
Boot lid
side skirts
Black metal intake pipe
Half shafts
fuel filler neck
fuel lines
Fuel flap
power steering pump
wheels/tyres
wheel jack
plastic knob cover for light switch
metal panel between boot and back seat
Metal trim around driver and passenger windows
Coolant temperature sensors
Speedo cable
window washer/wiper knob
alternator tension bracket
hubs/5 stud conversion
Driver's door power window relay
Accelerator pedal and cable
Brackets that attach the stereo in the centre console
bonnet support rod
Consult cable
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
