hey mate,
I need the exteranal moulds around the doors, that screw onto and between A and B pillar onto the shell and house the rubber.
please ring or sms me on 0438 600 350 if you have them
Sorry, they're gone already.
  • Replies 158
Posted Images
beaver trim (like a boot scuff plate) plastic piece between both tailights and goes around boot lock?
That thing - gone!
All rear seat belt bolts - gone!
  • 3 weeks later...
List update!!! Price drop!!!! Not everything available is listed here, so feel free to ask!
r32 gts-t shell - $offer!
Engine mounts - $20
Lower dash trim - $10
Door cards $30 for both - passenger door card has a tear near the mirror - easily fixed
Mirror triangle cover thing - $20
dash in good condition some very small bubbles (didn't notice until i found out these things bubbled up) $100
centre console storage thing between the seats $10
centre console surround that the storage thing connects to $10
rear wiper motor $20
passenger door with window and motor (minus door card and mirror) $40
dash cluster surround (minus switches) $30
Passenger side A pillar trim $20
boot trim minus cover for wheel arches and boot carpet and the plastic thing that goes over the lock and the driver's side cover bit $20
Mirrors - $40 each
drum brakes (in bits and pieces) $10 for both
tail lights $40 each
rear bar $40 - has one dint and one scratch
passenger side front guard (has slight bend) $20
kick panels - $10 each
Rear callipers $150
Rotors x 4 $100
brake booster $40
stock dump pipe to cat including sensors $30
Pod filter $20
AFM $100
hicas rack $40
fuel tank $50
fuel pump $30
Interior carpet $30 - has a tear in the driver's side (probably easy to conceal/fix), otherwise perfect
Centre dome light (without cover) $10
front reading lights $15
roof lining $30
stock crossover pipe including BOV $40
rb20 power steering reservoir (minus cap) $15
A/C compressor $10
boot hinges $20
front windscreen wiper motor $40
HICAS computer $30
steering column minus bottom bit of the steering shaft $30
alternator $free (not sure of condition - i think a bit of battery acid spilt onto it or some crap, doesn't turn easily)
hazards/tune/wiper switch (headlight switch already gone) $20 each
Passenger side rear quarter trim arm rest thing $20
Headlight wiring loom minus front indicator plugs $30
Stuff that's gone -
hand brake handle/cable
centre vent - $80
driver's side round vent - $40
Driver's side rear quarter trim $20 each
rear wiper arm
dash cluster (218,635kms) $30
indicator stalk $40
Driver's side A pillar trim
glovebox $50
sun visors $20 both
rear vision mirror $20
door seals - driver's side has one crack in it, passenger side perfect $60 both
passenger side quarter window $60
driver's front guard (rooted from accident) - free!
bonnet (rooted from accident) - free!
Front callipers x 2
rb20det $offer!!
starter motor $50
Centre dome light cover
rb20 power steering reservoir cap
Climate control panel $60 - not sure if the lights in it work
bonnet hinges $20
front seats
rear seat
front wiper arms $20 for both
Washer bottle $20
rear pods $70 pair
Stock manual ECU
clutch+gearbox etc for manual conversion (still have flywheel)
passenger seat belt
interior mats
6 x injectors
Trim around the steering column
Turbo
Power Steering Rack
Stock coils
Ignitor
Driver's side door (just the door itself and window/motor mechanism)
Passenger side vent
Headlight switch
centre console tray holder thing
fuel pump cradle. Still have fuel pump
front seat buckles
ash tray
front fuse box fuses/relays/whatever
driver's side window control
diff
b/c pillars
locks/keys
brake master cylinder and 3 brake lines connecting to it.
Driver's side rear quarter window
inside passenger door mirror cover.
Boot lid
side skirts
Black metal intake pipe
Half shafts
fuel filler neck
fuel lines
Fuel flap
power steering pump
wheels/tyres
wheel jack
plastic knob cover for light switch
metal panel between boot and back seat
Metal trim around driver and passenger windows
Coolant temperature sensors
Speedo cable
window washer/wiper knob
alternator tension bracket
hubs/5 stud conversion
Driver's door power window relay
Accelerator pedal and cable
Brackets that attach the stereo in the centre console
bonnet support rod
Consult cable
Front sway bar end links
Stock cat
Passenger window switch
2 x rear seat "JESUS CHRIST!!1" handlebars
Passenger side interior door opener cover
rear demister switch gone!
Suspension x 4
Plug for front driver's side indicator
Heater core
Boot/fuel cap cable
3" catback exhaust - straight through muffler and doesn't get attention (looks kinda stock)
Stock rb20det side mount intercooler
Driver side boot trim quarter panel cover
Rb20det engine loom
Bottom part of steering shaft gone (the bit that connects to the rack)
front windscreen
rear windscreen
Passenger side front indicator plug
Edited by verger
    • Mount some of these on your dash? https://www.greddy.com/products/16001720
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
