So as some may know, I've been having some oil pressure issues lately. Last event it got worse though and now oil pressure is around 30psi on a cold start.
A few mates and I fitted a new oil pump yesterday, checked the pickup etc and all was well. But I've still got the same issue.
So are the clearances too big in my engine ? I don't know what else it could be.
I have a standard 25 with bigger turbo, standalone, oil cooler etc. Can an oil cooler and remote mount filter affect pressure?
I don't know where to look and I'm thinking it's time for a new engine.
Not going off a standard gauge btw, got an electirc aftermarket item that is pretty accurate (read 2psi at wakefield when lifters started tapping).
Anyone heard of shit like this before?
I'd really love to get the 33 to Wakefield Matsuri this weekend if I could.
Cheers guys!
Adam.
Edited by Run-It-Hard
https://www.sau.com.au/forums/topic/383546-low-oil-pressure-real-low/
doesn't look like there is oil in the coolant, but I've probably run the car for 5 minutes max. Oil is milky looking in the oil cooler, and lines. So I'd presume if I were to drain it, it would all be milky.
Well I'd say based on that u probably have blown a head gasket, I'd be draining the lot and inspecting it
Could well be ur oil pressure problem, so probably a new gasket as well as an engine and coolant flush...
Unless anyone has some other theories....
If u ran it long enough to open the thermostat I may well find oil in ur coolant
Edited by GTR_JOEY
So, managed to get the head off tonight. Suspisions confirmed, headgasket is a goner. Interesting reason towards it though.
I don't know how, or why it would happen. But the head and block have been elongated in two parts (both on the passenger side). I'm guessing snapped head bolts or what not. So it makes me think why the head has been off in the first place. The piston tops look amazingly clean for a suspected 140k engine ... hmm.
Anyway, so the holes were elongated and a inner ring was placed in there to fill the new OD. But whoever has fitted this has also elongated the head gasket to suit. The photo below is probably where it failed, as it's right next to the water/oil jackets. So yeah as soon as we pulled the head gasket off and touched the enlongated part, the copper washer built into the gasket fell out.
So the plan of attack is to get another pair of inner rings in the same dimensions, cut two down to suit the block and leave the current two in the head. That way it'll still bolt together without needing to chop up the head gasket.
Thanks for all your help Joey, legend!
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
