+1 for CRD. They did my 2nd rebuild.
$400 to get Tony (aka Fridge) From Eurotow to put it on his awesome truck and take it up to Sydney. You can drive it back.
My GTR has done this trip and no hassle and no damages. I have even traveled back with Tony in his truck.
  • Replies 83
Posted Images
$400 really? Fridge has helped me out a lot over the last couple of weeks I dunno why I didn't even think to ask him lol.
So CRD are as good as I've heard then.
Hmmm as you can imagine this is all a massive headf$&k lol
The main problem we faced though was actually getting the car there as we don't have something capable of towing a car trailer. That's the only reason we've decided to get it done in Canberra.
As others have said, Fridge does it for a good price. Failing that you can hire a Nissan Patrol from Hertz out in Queanbeyan - I did this with a car trailer, whole thing cost less than $300 to get a GTR back from Sydney.
Speaking of Canberra, I went out to the place that zebra suggested and it didn't look like it had been used in a while.
Fairly certain Pro Engines moved out of the address listed on their website years ago now. No idea where the current location would be.
Aside from CRD, if you get the engine out you can send it down to Race Pace in Melbourne. I got my current motor from them and it is awesome to drive, feels very healthy and responsive (and I flog the piss out of it, with a T04z hanging off the side). Just another option.
But all that aside, hopefully you have just spun a bearing and not caused any other damage. If this is the case it should be relatively cheap to fix given it sounds like you have all the other go fast bits already.
Edited by Amaru
Just out of curiosity how much did you guys spend on your rebuilds? You don't have to say if you don't want to.
And Richard you said you just had your second rebuild done, where was the first done and what happened?
I did my first rebuild with Pro Engines back in 2003. Cost was around $8000 and for that I got standard rods prepped, Arias forged pistons, ACL bearings, ARP studs, a bit of headwork, new gaskets etc. That motor lasted around 25,000kms running ~340awkw (HKS 2530's running at 25psi).
Second "rebuild" was more of a freshen up of the first rebuild I had. New bearings, aftermarket rods (cant remember what they were), new gaskets and studs etc. Cost was around $5k from memory and this was in 2005 and done by Pro Engines. This motor did 0km.
Third motor I am on now is the Racepace motor - cost was quite a bit, but worth every cent :D
Edited by Amaru
All of this is making me feel a lot better about our situation. Thanks heaps guys. I guess first step is finding out exactly what's ruined and needs fixing and then just go from there. The whole swap another engine in idea has gone out the window lol.
A little off topic....I work in fyshwick on Newcastle street and across the road from my shop in the carpark near j racing is a white 32 GTR with a black front bar that I see nearly every day, does it belong to anyone on here?
From memory the first rebuild was about $10k with new JE forgies, Eagle rods, Poncams. ACL race bearings, ARP headstud kit, full head service etc...
Out/In cost $2800 extra plus consumables like all fluids, sparkplugs and gaskets to bolt the boltons back on. Same shop Nik used.
So $12k to $15k is on par with ESP's quote but thats with all NEW pistons, rods, cams, bearings so you should come out if most of your internals are ok for $7k plus out/in of your block.
Second rebuild would have been the same except I needed new turbs, new JE Pistons oversized and I also decided to go more the full monty with 9.5l sump, Nitto oil pump & crank collar, Koyorad, CAB, 2L custom oil catch can, Haltech platinum pro ecu and the list goes on and on. This one is In the vicinity of just over $20k - CRD
Oil starvation twice with big end bearing failures scared the bejeezus out of me.
Now I have more oil than Texas in the GTR :rofl2:
The one thing I tried to take into account when choosing a GTR was oil starvation.....i knew it was gonna happen at some point, just didn't think it would be the day after we picked the car up lol.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
