  • Replies 41
was thinkin bout this one...
Its supplied by electus distributions who are the wholesaler for most of Jaycar's products, they have a special right now for 3 CB radios,a nd I think this one was $25 or something... bargain price really....
maybe we should organise a group buy for before the cruise
https://www.sau.com.au/forums/topic/38371-uhf-radio/#findComment-777004
Boyz If memory serves me correct those UHF are a POS! For $25 I can guarantee that yes it may cover the 5km range but It will break out alot and wont be clear...
acsplit arrange the group buy a while back as his work sells them... spend the $90 or so on one of his as they are quality.. I have one and have used the ones your looking at and there is a huge difference in quality
https://www.sau.com.au/forums/topic/38371-uhf-radio/#findComment-777460
http://www.dansdata.com/digitalk.htm
and
http://www.strathfield.com/Product.asp?ProdID=201
Contacted Electus, turns out its the same CB but the older housing (ie its cosmetically out of style) hence why they're clearing em at $23... and for that price even if it only works for 500m its f**kin awesome.
Jaycar is still sellin em at $42
https://www.sau.com.au/forums/topic/38371-uhf-radio/#findComment-777547
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
