brand new Magnaflow full stainless muffler
3" in
twin 3" out (might be able to reverse im not sure)
ruff dimensions 560x300x100mm
$200
Fuel system:
Bosch 044
billet mount
2ltr polished surge tank
russel inline filter
-6an earls lines and fittings
malpassi fuel regulator
$500
basically brand new, only driven in and out of the shed and a couple of burnouts
adaptronic e420c
nissan rb patch loom
3bar map sensor
$1000
25mm longer s chassis lca
notched for more lock
currently has brand new s13 taper ball joints
$ not 100% sure
nigel petrie s14/s15 knuckles
does not include hub brakes etc, just the knuckle
$350
basically new KKR s13 rose jointed caster rods
these have been shortened by 20mm on a lathe for more adjustment
$150
pair of (x2)
weds kranze 18x10.5
near new 245/45r18 achillies tyres
repolished lips
2pak black centres
centre caps and gold weds bolts
$1000 for the pair
turbo setup:
holset hx35w
professionally rebuilt by "rob lupo" local turbo guru
has since only been started a few times and a burnout
wastegate flapper welded shut
rb20/25 ebay stainless manifold
braced, and heat wrapped
speedflow oil feed line
high temp rubber oil drain
orange heat/flame resistant tube over both lines
turbo beanie
includes dump pipe flange and partly made dump pipe
however does not include a wastegate
$800
These turbos have made some good numbers on rb25's and 25/30's
would need a wastegate and wastegate flange and you'd be away 300kw+
selling for a mate: Genuine Greddy type r external gate
48mm (claimed)
unknown spring pressure
$250
(perfect companion for my turbo setup)
Edited by Johnny_B
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
