I wouldnt think so, but Im only guessing, imagine the reflection of lights at night, or even the reflection of the sun...
This
and the stone chips on the front bar and bonnet :P
Not such an issue these days... new products can help here :whistling:
i guess there is one way to find out
i'll call vicroads tomorrow and i'll let u know
Also just to let you know, chrome wrap is super expensive :thumbsup: (people think carbon costs a lot...)
https://www.sau.com.au/forums/topic/384071-vinyl-wrapping/#findComment-6129339
  • 3 weeks later...
^ agreed. wonder what the RTA will say about me vinyl wrapping half my car
If it's only half, you probably wont need to notify them.
If it's more then you'll most likely need to change the color of the car with the RTA.
I did this after wrapping the 34
https://www.sau.com.au/forums/topic/384071-vinyl-wrapping/#findComment-6161705
^^^ dont do it, the stuff has a texture to it, I reckon it would get mega annoying to wash...
matt or gloss colour not a worry, but unless you can find a smooth CF vinyl or plan on storing youcar in a garage and its only a weekend driver dont do it...
https://www.sau.com.au/forums/topic/384071-vinyl-wrapping/#findComment-6162038
Yeah I was thinking about this too, I used the textured stuff on the pillar stuff on the outside of the car and it is a pain to get some dirt out of, especially bird shit... I was looking for some matt vinyls but really have no idea where to source them. My car is white and I wanted to try and go for an urban camo look
camo skyline on our stand
https://www.sau.com.au/forums/topic/384071-vinyl-wrapping/#findComment-6163440
PM'd mate
https://www.sau.com.au/forums/topic/384071-vinyl-wrapping/#findComment-6164017
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
    • Thanks guys - I have been overseas for a hectic many weeks , so haven't had time to chase any of these up.  Some of the suggestions are for 4.1 ratio, which I already have, and a 3.5 at Lonsdale, which is also too tall.  Really looking for 3.9 or even a 3.7 LSD, either with M12 bolts. Will look some more.
    • Yeah sounds like the swirl pot isn't being fed from the return line, would be made even worse by the high flow pump.
    • This is the R32 one and the inside of the tank should look like this. which has an internal swirl pot, that the return line must empty into. (Interestingly, because the GTR tank is plastic it misses out on the swirl pot.) That is a potential cause for an aftermarket pump hanger to mess things up. Maybe the return is cut short and squirting over the side.
