i have for sale my 3000klm old 3582r turbo.
It has damage to turbine side of turbo.
Turbo still works, was working right up until removal (change of engine internals). still feels as good as my new one i just got.
Comes with brand new housings and a 1.06 rear housing.
Located in Bundaberg 4670
Chasing $700 or best offer.
NOTE: does not come with the fittings in the CHRA showen in photos
will post at buyers expense.
Contact via post on thread, PM
photos:
damage to rear wheel
New vs old (ad is for one on right)
front wheel is like brand new
the cover that came off the turbo to show it didnt touch the front housing
Video of turbo to show it still spins free
Edited by nick81xd
https://www.sau.com.au/forums/topic/384212-garrett-gt3582r-damaged/
$700 is steep... I had the exact same turbo with the same problem but not as bad. To get it fixed was a pain in the arse and wallet. I recon if you are a little flexible on the price, this will go quick.
  • 1 month later...
  • 4 weeks later...
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
