  • Replies 5.5k
Posted Images
There could be no worse result for Massa than this...
His team mate on the top step, standing next to the guy rumoured to be his replacement, while he finishes 100 seconds behind... Might need to be locked in that padded room with Vettel
mmmm web stream getting it thru some software on my mac called xbmc and some other addons for channels, its not too simple to do however
Any links and help to setup?
they are probably frantically trying to download an anthem to play for him, LOL
LOLOLOLOLOL
Interesting season ahead.
Perez should have won.
Damn team played him twice. No pit and wrecked his flow on the radio.
hahahaha, some silly bitch had a bit of a rant on the ONE fb page complaining about people on facebook spoiling the results by talking about it on facebook, because she lives in an area that only gets channel 10 and not ONE so has to watch the delayed broadcast.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
