  • Replies 5.5k
Posted Images
How the hell was than not vettels fault? I only saw it once, but it looked clear that vettel cut in too soon and paid the price. stop whinging ya farkin sook. At least button's man enough to admit he screwed up.
Any links and help to setup?
LOLOLOLOLOL
Interesting season ahead.
Perez should have won.
Damn team played him twice. No pit and wrecked his flow on the radio.
It didnt work too well for me thru out the race, p1-p3 and qualifying + the 30 to hour before the starts were fine to watch tho.
Are you on racingfor.me?? theres a thread with few bits to the program to get it to work. but its really just giving you the streams that are avaliable on the web, since most of them are just whored all over the web and each website has pretty much the same links come race time.
In this thread you will have a few options and quiet often a decent link to a stream thats working. someone recently posted a hdtv thing i am yet to try since im using a mac
https://www.racingfor.me/index.rfm?cls=21&pg=viewtopic&f=22&t=1093
Going to need to work something out soon so i can just stream skysports.. i dont mind if i have to pay for it really. but another 5 years of trying to watch it on one is going to be shithouse..
most of us would be members i'd think...
there is also something else you can look into.
i did try that hdtv player just now and it seems ok, pretty much like foxtel with every channel possible.. i ran it on bootcamp for mac (windows partition) and it threw up a few virus things, but since i dont really use windows for anything important i wasnt bothered. probably a false virus thing anyway..
http://www.2shared.com/file/-jq6AgvM/HDTVPlayer034.html
http://en.espnf1.com/malaysia/motorsport/story/74313.html
http://en.espnf1.com/f1/motorsport/story/74343.html
bit of a harsh penalty i think but HRT should take him out every race, worth a 20sec penalty for us to loose the tool
It beats me what footage the stewards had of the contact.
the camera angle is deceptive. From the rear it looked like SV cuts across on him, from the front that's clearly not what happened.
http://www.youtube.com/watch?v=LxVxZeYZ_IU&feature=related
Edited by hrd-hr30
I found a link and I have to agree that looking at it from other angles, Karthikeyan moves over. SV was slightly squeezing him on the exit and could have moved back to the right of the track.
Just watched a few vids of the incident, both on-board and front/rear views... I still think Vettel could have easily got passed him without incident.
As you exit that right hander, you immediately aim towards the right of the track to set up for the left, which is what Karthikeyan was doing. If he had have continued straight he would've been off the track.
I agree back markers should do everything to get out of the way when being lapped, especially when they're not fighting for position with any other back markers, but in this case it's not that simple given the series of corners it happened in. Karthikeyan had just been lapped by someone else mid-turn, and would have been lucky to see Vettel coming up behind him immediately after.
The penalty doesn't really matter too much in the scheme of things, but in reality Vettel had a shit load of room to the right that he could have been in, instead of leaving nothing more than a car width on a track where a wheel outside the line could end the other guys race..
you say yourself he left a car width. how much more do you want for a bloke 3 laps down?
there's no rush to get back over to the other side of the track, but even if there was, you don't move over if there's another car still alongside you! pretty simple. and that's not what Karthikeyan was doing anyway, he just tucked in behind Vettel, and even went left again after that. He was still mid track by the braking zone, and not because he was being squeezed...
Edited by hrd-hr30
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
