  • Replies 5.5k
Posted Images
all those things are true, but it doesn't mean you can run another car off the road just because you want the points and refuse to accept that another car may have actually passed you.
Was Maldanado ever actually in front though?
don't have to "actually be in front" to deserve to be left some room. Right up alongside will do.
if you've just poked you wing in there, or its your front tyre up to their rear tyre then you've got no claim on the corner and should GTFO, but when you're fully alongside, you do have some entitlement to racing room.
maybe I should have said "...refuse to accept another car may actually be passing you..."
Edited by hrd-hr30
Just found this;
20.4 Manoeuvres liable to hinder other drivers, such as deliberate crowding of a car beyond the edge of the track or any other abnormal change of direction, are not permitted.
How they penalised Maldonado and not Ham has me beat.
edit. Kimi's bird isn't great looking in that pic but he has the richness covered well and truly.
Edited by NISMATT
I fail to see how anyone here can support pasta in that move.
ALL the good drivers shove the other off the track to overtake to ensure no chance of them coming back.
Here is pasta on Webber same race:
edit: Also my 2nd favourite driver is Kobayashi. The overtakes this guy makes and the good ol' wheel tap on the way through. Legend!
Really want to see him in a top car.
Edited by 10 4
I don't support Maldonado's move by any means it was a dick move but rules are rules I'm just puzzled why they aren't consistant. If Webber and him crashed then they might have taken a look at it same as Rosberg got away with it in Bahrain because nobody got hit somehow. Also the lap previous Ham left a car width for Kimi and he should have done the same for Maldonado.
Edited by NISMATT
the fundamental difference in the above Maldonardo Weber pass is that by the time he runs Weber out of road, Weber only has a front tyre overlapping his rear. Hamilton ran Maldonardo off the road when they were fully alongside each other.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
