Hi guys selling my s15 that was just imported from JAPAN it's a Silvia s15 spec-R jap spec with the upgraded turbo so it is faster the the Australian standard s15s it is all stock ready for me to do it up myself but unfortunately I'm having trouble with my family and my mum wants me to sell it... It is a beautiful ride and is fast ! It's perfect for a garage that's wants to do up a Silvia for autosalon and I also got a brand new clutch for it and hid headlights... Also if you buy this car I will chuck in a full uras body kit a brand new intercooler system genuine Avs rims and the Japanese rims that came with the car for just another 2000
post-88468-0-87692900-1322587790_thumb.jpgpost-88468-0-79481000-1322588427_thumb.jpgpost-88468-0-01561800-1322588300_thumb.jpgpost-88468-0-37267000-1322588135_thumb.jpgpost-88468-0-80349500-1322588007_thumb.jpg
Edited by kalel17
https://www.sau.com.au/forums/topic/384458-silvia-s15-for-sale/
