Parting My Car :(
hey all.
im parting my car, as i CBF waiting for it to sell.
so here goes..
shell - $4500
1993 mspec, Clean rego;d shell, sunroof, gtr front guards, geniune N1 gtr front bar, gtr front indicators, BRAND NEW BC coilovers, rear camber arms, front caster arms, hicas lock bar, vanquish roof spoiler, origin s13 boot lip, CF vented bonnet, bolt on rear guards, r34 gtt front brakes with slotted rotors.
NO rear seats, no drivers seat, no diff, no engine, no gearbox, no wheels.
can make cheaper for removal of parts.
engine built rb25 - $6000
s2 RB25, RB25 gearbox with excedy heavy duty brass button clutch
Mahle forged pistons
spool rods
crank was balanced, grub screwed
block decked, honed, acid dipped
block grout filled
nitto oil pump
ross metal jacket balancer
n1 water pump
oil restricters
head to sump oil drain
refreshed head
gtr valve springs
tomei pon cams
r34 neo CAS
r32 gtr rocker covers/timing cover
mines cam cover baffles
working vct
gates timing belt
has done about 1500kms worth of use.
made 350.1rwkw at horsepower in a box on e85.
RB25 gearbox + clutch - $1400
excedy heavy duty button clutch
VSKF - $3000
18x9-6 and 18x10.5 -5
225/40 and 235/40 neutons
black with chrome dish
fuel setup - $500
external pump, surge tank, magnaflow fuel filter, speedflow fittings for pump surgetank and filter
gt3076 .82 + full lines - $1600
surge slotted gt30, .82 exhaust, speeflow fittings and braided lines
1500kms use max.
helps highmount mani - $850
50mm gate port.
Plazmaman intake plenum - $900
rb25 throttle body inc, all fittings and bottom half of plenum also
id1000cc with rail, aeromotive FPR, lines + speedlow fittings - $1200
z32 + plug $200
defi BF gauges x3 - $800
oil temp, oil pressure, water temp, control unit, light up white with black background
bride style seat with superlow rail - $450
takata style harness - $150
tail shaft suit rb25 in r32 - $200
made by hardie spicer
power fc + hc - $1400
i have all my pics on my phone so please txt me and i can mms you what you need to see.
or see my car sale thread for some pics.
contact 0433 290 801.
cheers
shell - $4500
1993 mspec r32
Clean rego'd shell
sunroof
gtr front guards
rear camber arms
front caster arms
hicas lock bar
origin s13 boot lip
CF vented bonnet
bolt on rear guards
r34 gtt front brakes with slotted rotors, A1RM pads
nolathene bushes up front
3inch cat back
comes with fmic and piping to suit forward plenum
has engine loom to suit rb25 in r32
CD player, front splits and 6x9 rears
VSKF - $300018x9-6 and 18x10.5 -5225/40 and 235/40 neutons black with chrome dish
cusco 2way diff - $750
fuel setup - $500
s2 splitfires - $450
sms me for pics - 0433290801
 Share
    • I'll chime in here with my experience. Motec is great if you have the money and know a good person to support you. They don't really offer retail support and the dealers make SFA margin on the product, so the business model is setup for you to be supported by a dealer. I'm lucky enough to know a guy who's ex Motec and very generous with his time and is a total boffin. In addition to that, I also use Brad Sherriff who's an absolute legend to work with. The downside to Motec is the software isn't very intuitive, pay to play, poor/limited online support and costly upgrades.  I've not owned an Emtron myself but a good friend runs a performance workshop in Melbourne who is an Emtron dealer. They won't be fitting any more to customer cars because of the poor level of knowledge within the Emtron support team and lack of ability to solve issues with the platform. Not to mention the circumstances around the establishment of the product and company in the first place. I've run Motec's since the old M8's back in the early 2000's so I'm certainly not without a bias but I look at it like this. Everyone acknowledges Motec as the best consumer grade product without spending mega dollars on Bosch Motorsport / Life Racing and so on. When you consider the real cost of your car (not what you tell your mrs) the cost difference between an Emtron and a Motec is tiny, why would you compromise over a few hundred dollars?
    • Closer to getting the shit box back on the road. That long hose, took 2 months to acquire. However the rest were all already to go same week I ordered them. For those playing at home, that long hose is for a RB25DE N/A motor, as they don't run a water/oil heat exchanger, the hoses underneath the plenum are much more elegant and not a maze of shit.
    • One thing you may be able to leverage is the fact that the R34 N/A has the same setup as a S15. The S15 also is a car that gets 350Z diff swapped, so they will also likely have this problem. The caveat of course is it's possible the dash is different between the R34 NA and the S15, but the subframe/sensors/axles/diff setup are the same. I can't remember now as it's been too long, but I don't generally think people need to swap dashes between the N/A dash and the turbo dash when they do things like change the gearbox out, turbo their car, manual swap it, it's just not something I've seen mentioned so this could be compatible.
