11 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
lads,
finally got my 34, now running through a major service trying to undo some of the abuse this poor car has been dealing with.
gotta change all the coolant lines right throughout the bay, due to rust damage.
wondering, pros / cons between rubber and silicone?
anyone run silicone? all info will be muchly loved
catch!
https://www.sau.com.au/forums/topic/384546-rubber-vs-silicone/
Genuine Nissan hoses is the best way to go, cons of cheap silicone kits is most people have complained that they develop pin hole leaks, even when replacing that hose with another.
Gates hoses on the Upper and Lower radiator are cheaper than genuine, and come with decent clamps.
You don't ask for skyline bits take your rubbers there and ask them to see if they can closely match the shape and size you will end up with 10 hoses from different cars but if they if it does not matter. If not buy heater hose and make it work. I had some hoses from a jeep all sorts of cars trust me much cheaper option otherwise buy Nissan
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
