  • Replies 75
Posted Images
Yeah, I was somewhat surprised and very happy with the results. Another reason I think the kilometres on the car are genuine. And I guess engine was the worst case scenario for not making power and would be most expensive to fix so big relief lol.
  • 2 months later...
Gday fellas, thought I'd give you an update. I bought this car off Livewire a few days ago and I've just completed it's first service. Ran an oil flush through it, took three hours and 4 trips to auto1 to get the oil filter off, it was branded AUTOMAC with japanese writing? easily half the size of the ryco replacement and was full of sludge... Revving nice and smoother now, far better torque down low and the oil pressure is sitting just below 4 and not 2 (let me know if this isn't right please?) But it's now developed a miss on boost so I'll be getting new coils and plugs on monday, rewire the fuel pump straight to the battery and get a retune
Try some good ole fashioned trial and error like XKLABA and then you really learn things.
All these idiots who get their cars built at a workshop and then have the audacity to preach that their mechanical prowess is on the same level as the engine builder/tuner - Get off your high horses and put your money where your mouth is, by building your own damn motor.
Such an angry first post
I ran a wire from the back of the alternator, straight from the horses mouth so to speak
Whilst i completely agree with this statement, i have to point out a few things, at least that relate to my situation. Not every one has the time, facilities, or tools to build their own car..
But yes, im not one of those "idiots". They get on my nerves too :)
OP, awesome car. I installed my own fuel pump too :) was a pain in the ass! But got there in the end. Mine was in there tighter than a sphincter holding back gas in packed cinema lol.
If anyone is interested here's a list:
  • Timing was good
  • Spark plugs were incorrect coppers and were showing signs of overheating
  • Coil pack #2 had visible burn marks
  • Idle control was not set
  • AFMs were set as RB25 with too much K-factor correcting, they are stock NOT nismo
  • And last but not least stock turbos...
  • Timing was good
What heat range where the coppers?
STD coil packs after 20 years of operation often have burn marks in the side. Not a good thing but not uncommon.
Idle control not set? Did the base bypass valve screw need adjusting?
Were the turbos n1's -as in steel wheeled STD turbo's?
Ok im thinking the turbo's are steel wheeled. Similar to -7's. Even if they arent it should still make the power.
Are u 100% sure the AFM's are stock. The nismo's are in a stock size casing so they are bolt on.
6 heat range is fine but 7 is better to help prevent pre ignition.
Who worked all this out for u?
Have u tried changing cam timing?
I'm thinking the same about the turbos. Sean at efi did the tune and he was very confident it's stock.
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is <2k rpm, going to WOT sees the MAP go +ve even before it crosses 2k and it has >5 psi by the time it hits 90 km/h. That's still <<2.5k rpm, so I think it's actually doing really well. Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 😎
    • Oh, it's been done. You just run a wire out there and back. But they have been known to do coolant temp sensors, MAP sensors, etc. They're not silly (at Regency Park) and know what's what with all the different cars.
    • Please ignore I found the right way of installing it thanks
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
