  • Replies 75
Posted Images
Yeah, I was somewhat surprised and very happy with the results. Another reason I think the kilometres on the car are genuine. And I guess engine was the worst case scenario for not making power and would be most expensive to fix so big relief lol.
  • 2 months later...
Gday fellas, thought I'd give you an update. I bought this car off Livewire a few days ago and I've just completed it's first service. Ran an oil flush through it, took three hours and 4 trips to auto1 to get the oil filter off, it was branded AUTOMAC with japanese writing? easily half the size of the ryco replacement and was full of sludge... Revving nice and smoother now, far better torque down low and the oil pressure is sitting just below 4 and not 2 (let me know if this isn't right please?) But it's now developed a miss on boost so I'll be getting new coils and plugs on monday, rewire the fuel pump straight to the battery and get a retune
Try some good ole fashioned trial and error like XKLABA and then you really learn things.
All these idiots who get their cars built at a workshop and then have the audacity to preach that their mechanical prowess is on the same level as the engine builder/tuner - Get off your high horses and put your money where your mouth is, by building your own damn motor.
Such an angry first post
I ran a wire from the back of the alternator, straight from the horses mouth so to speak
Whilst i completely agree with this statement, i have to point out a few things, at least that relate to my situation. Not every one has the time, facilities, or tools to build their own car..
But yes, im not one of those "idiots". They get on my nerves too :)
OP, awesome car. I installed my own fuel pump too :) was a pain in the ass! But got there in the end. Mine was in there tighter than a sphincter holding back gas in packed cinema lol.
If anyone is interested here's a list:
  • Timing was good
  • Spark plugs were incorrect coppers and were showing signs of overheating
  • Coil pack #2 had visible burn marks
  • Idle control was not set
  • AFMs were set as RB25 with too much K-factor correcting, they are stock NOT nismo
  • And last but not least stock turbos...
  • Timing was good
What heat range where the coppers?
STD coil packs after 20 years of operation often have burn marks in the side. Not a good thing but not uncommon.
Idle control not set? Did the base bypass valve screw need adjusting?
Were the turbos n1's -as in steel wheeled STD turbo's?
Ok im thinking the turbo's are steel wheeled. Similar to -7's. Even if they arent it should still make the power.
Are u 100% sure the AFM's are stock. The nismo's are in a stock size casing so they are bolt on.
6 heat range is fine but 7 is better to help prevent pre ignition.
Who worked all this out for u?
Have u tried changing cam timing?
I'm thinking the same about the turbos. Sean at efi did the tune and he was very confident it's stock.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
