  • Replies 52
Posted Images
At least the wrecker long motor isn't too expensive compared to the RBs. Wonder what sort of operating conditions made it go in the end? All the stories you hear about the jays being unbelievably abused and still living happy lives you must think this think must have gone through hell or had virtually no maintenance...
Ye, before it came to Canberra it had a rubbish life by the looks of it, The guy I bought it from spent a small fortune getting it to where it is (was)
Had a cam cover off and inside the motor is blacker than the paint ont he car lol
Hahah yeah, it happens, nothing I can do about it
I would like to rebuild the motor and keep it matching #'s if possible
But 5k+ vs 1k lol
See what happens, will be sure to post up pics of what it looks like inside when I get the motor out and stripped
  • 3 weeks later...
well...a development
front turbo rooted....absolutely rooted...never seen so much oil in a turbine hosuing before lol
comp test done just now...stone cold and dry
#1 - 155
#2 - 165
#3 - 145
#4 - 140
#5 - 140
#6 - 158
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
