I have a 92 R32 gtst and want to replace the low beam projectors, was going to get a JDMyard kit but they only have the h1 kits not the h3c, but they are quality kits with the stealthy black ballasts and 5 year warranty. :(
So question is, where do I get a decent (with warranty) set of 6000k HID in h3c (which is apparently plug and play)
or do I just suck it up and mess around with trying to modify the lights to fit the H1 kit?
https://www.sau.com.au/forums/topic/384948-hid-help-needed/
You should easily be able to pick up a quality pair of HID 6000k bulbs from ebay with warranty, Just put in what you are looking for (H3C 6000k HID bulbs). All the sets of hids i have come accross all have the same wiring to and from so they should be plug and play. I recommend putting in 55W into your search as well. They are much much brighter then the standard 35W.
https://www.sau.com.au/forums/topic/384948-hid-help-needed/#findComment-6140130
see if you can find a dealer for the brand 'ultra' hid kits. Ive get a set of h3c's to put into my 32 gtr. The Ultra "virtual daylight" ones are the best
we've found that we sell. They retail for about 300-350 for the kit.
https://www.sau.com.au/forums/topic/384948-hid-help-needed/#findComment-6147376
http://www.ultraauto.com.au/HID-Xenon-Kits/35W/Virtual-Daylight/virtual-daylight-xenon-kits-slim
Theres a link to the kit, only thing we've found better than these are the philips hid kits which are crazy prices like 500 or there abouts.
https://www.sau.com.au/forums/topic/384948-hid-help-needed/#findComment-6147379
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
