I havent been around for a while guys. Anyways, shes up for sale.....
R32GTR with a 2.8L stroked RB26DETT
Fully built motor with all new parts. The only thing that wasn't replaced is the dipstick..
A lot of work has gone into this car yet it's time for her to go.
All work completed by Ray at RE Customs and Rob Sabbadin Automotive
Only serious buyers please.
Engine
Oil filter assembly & oil pressure switch
600cc Nismo Injectors
N1 block
Tomei 2.8L stroker kit with cooling channel pistons
Tomei IN & EX Adj. Cam gears
ATI harmonic Balancer 600HP
HPI Dumps
Mines triple flow cam baffle plates
Nismo big operating cylinder. (clutch)
Nismo Engine mounts
Nismo fuel pump
Tomei oil baffle plate
Tomei oil filler cap
Tomei Ornament plate
Micolor clean sandblast prime and paint all motor covers/pipes with custom RB28 work on front cover
Genuine TWIN TURBO badge
Custom external oil return line
Hard pipe kit for intercooler
Black silicon hose set 14pce
HKS Oil cooler kit Type R
ARC Titanium Radiator Plate
Splitfire coil packs
Blitz i-color option parts External voltage input harness
Blitz i-color option parts Temperature sensor
Blitz i-color option parts Pressure sensor
Nismo AFMs
Rebuild of stater motor and alternator
Blitz NUR Spec R Exhaust
3” stainless hi flow Cat
Just Jap Front Pipe
Nismo front and rear torsion bars
Brakes
Braided brake and clutch lines
Ferodo DS2500 Front and Rear brake pads
Front and rear slotted RDA rotors
Motul 5.1 brake fluid
Rebuilt ABS unit
Drivetrain
Race Clutch by Jim Berry Full Monty 4000LBS
Nismo strong release fork pivot
C's Short Shifter
Body & suspension
Lower door mounted door seals drivers and passenger
Upper body door seals 76860-04U01 76861-04U01
Genuine boot rubber stoppers 01658-01811 01658-00881
Front diff seals
N1 Headlights
Hicas Lock Bar
Genuine speedo cable (SHAFT ASSY-FLEXIBLE)25050-05U00
Reconditioned steering rack & power steering pump
Tint a car Midnight Express
Interior
Trust-Greddy Shift Knob
Power FC + Controller
Blitz SBC i-color
Custom interior LED lights to consoles etc
Cyberstork Aluminium bezel with chrome rings
320KM/H Nismo dashboard cluster
Genuine dash clear cover
Alpine head unit
Adapter for antenna on radio
Car alarm Cyclops P785 with turbo timer feature & Central locking
Mode Door Actuator (ACTUATOR ASSY-MODE)
Genuine rear upper trims.
Genuine Nissan floor mats
Greddy turbo timer
Stealth ATTESSA controller.
Contact via email to [email protected] only please. No PM's
Asking $28000ono
https://www.sau.com.au/forums/topic/384963-r32-gtr/
Kms on engine / chassis?
What oil pump?
What power is it making @ what psi?
ok the motor is around 10,000km after build.
N1 oil pump
i need a new power run yet it would be around 340awkw at 18-20psi
https://www.sau.com.au/forums/topic/384963-r32-gtr/#findComment-6147467
Just so you all know, my fiancée and I have found an awesome property that we really want to buy. I need the sale of the GTR to be quick to add to the deposit as im slightly short. Make me a reasonable offer
https://www.sau.com.au/forums/topic/384963-r32-gtr/#findComment-6149392
some ppl have good experiences with n1 pumps, some bad, but in general these days people use tomei or nitto as theyve been found the be most reliable.
I've had nothing but good experiences with N1 pumps. That being said, this isnt a new rebuild. This build was completed in mid 2008 with receipts to prove it. Since then it has always been maintained/fully serviced every 5000km. I had a complete new build done due to the previous motor rebuild failing a No.2 bearing at 11 months. I still have the bearing on my shelf!
This build was meticulous. Every possible thing was prepared to prevent a repeat failure as compared to the original motor.
I have said build a lot instead of RE-build. As this is a complete brand new motor.
The build alone cost me $30,000+
In saying all of this, I need to sell. I am desperate as I am buying a home for my fiancée and my family. We are sick of renting. This is the biggest step ever taken in our lives.
I don't want to lose my R yet I know I need to take a step back to get a few steps ahead and I can always buy a 35 in the future. :thumbsup:
This can be sold with or without a roadworthy. It could be bought solely for the motor for a track car or to fix up a blown motor. It could be bought for a daily as its bloody easy to drive. It could be used purely for a track car. My every intention was to build the ultimate streetable race car.
Ask questions. go for a drive with me if your serious. see what this car is capable of. and make me an offer. :cheers:
https://www.sau.com.au/forums/topic/384963-r32-gtr/#findComment-6155625
Ron, Good luck with the sale, I'm sure whoever gets this will be extremely happy. To me it seems pretty much the perfect street/track set up. Something like this temps me to get back into another Skyline.
G'day Graeme. It's been a while. Thanks for the support on the sale. Feel free to convince the missus to let you buy it!
As Graeme has mentioned, this is a great street/track setup. It is happily driven to the track and then will easily compete and then quite happily drive home again.
https://www.sau.com.au/forums/topic/384963-r32-gtr/#findComment-6163217
Hi everyone. Happy new year! My fiancée and I had the best news ever with the approval of our mortgage application yesterday. This being said, the GTR MUST and WILL be sold. If you are interested, please contact me either via my email address [email protected] or via PM.
Cheers! Ron
https://www.sau.com.au/forums/topic/384963-r32-gtr/#findComment-6171049
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
