R33 series 1, Clear red metallic ( the colour everyone calls burgandy..)
all standard apart from:
Greddy FMIC /piping & washer bottle
RDA slotted rotors & pads ( were only 5 months old at time of crash)
Enkei RS-Evolution lightweight rims (17's - all 235/45s)
Factory electric sunroof
Xforce exhaust which has been modified to fit standard muffler ( will bolt on direct just after rear axle, modified for the lovely people at the EPA. ;)
Also has adjustable suspension, from what i was told by previous owner - however will find out and update this information.
Engine is in the 190,000 range. Was running strong with no problems before crash.
Car was written off a few months back. Was still drivable after crash, was pretty much t-boned on the drivers side - so there is driver side damage to the car along with some damage to the passenger side.
Just wanting to get rid of whole car as will be moving soon. Looking around 1800 ono, which is pretty low considering the parts and also is very negotiable. Open to offers.
Will be putting up pictures later tonight and updating info as well. If interested, let me know
Edited by brettw88
car is a 1994 Gtst with the RB25DET engine
also, car is Auto..sorry forgot to mention
photos of car will be up later tonight.
Edited by brettw88
Hey dude.
Are you able to define Northern Vic?
Also, are you parting it out or trying to sell as a whole first?
Cheers.
Hey dude.
Cheers.
Cars located in Kilmore.
Selling as a whole car as stated, need it gone as its located on fathers property and he needs it gone as he is moving in next few months,
Cheers
in regards to the suspension, looks to be the standard adjustable that came with the car as told by previous owner.
will post pics when have some.
Edited by brettw88
