Can do that for you Neil.
I've got something a little better in the making for door handles.
Cutting the hole out for the original handle is okay but I've located some really nice billet handles that are used on some GT cars.
They will look far neater and don't cost alot
Place was a sea of blue covers tonight at lock up.
Yes we now cover almost every car during the day and night that is in the workshop.
Alot of things are happening over the next few weeks to expand the apeal of the workshop. Floor lighting under the hoists, a new fabrication bay is planned as well as a couple more belly lift hoists for cage work.
Here is the completed EVO 9 cage ive been working on for Dash Sport.
I received FIA homologation papers for the two 4130 cages in at the moment so work can now begin on those.
Nik Kallis' EVO time attack weapon and John Boston's new 180sx project for trackschool
Also have an Astra/opel for insight motorsport to do
I can think of another car in there to be caged too........... :whistling:
I was keeping your car quiet at the moment.....
Homolgation papers are due early next week for your cage ;)
It doesn't look the same as it did when you dropped it off the other day anymore.
Far less of a car remains now!
Good - now less typing and more working !!! :no:
I can do that, but I wouldn't even bother trying to do it without the car and the cooler.
I don't do "kit" piping or anything like that. There is no way you can do a decent job without the car. I've seen people try and it ends in tears each time.
Hey,
Tried to call a few times this week...you need a sexytary!!! lol
Can you pm/call/fb me re: having some -10 push lock fittings welded to my cam covers and fabbing up a basic catch can
Cheers
Andrew
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
