Hy guys i have alot of things that now just has to go
Big things i will not sned but pickup is available
in s.e suburbs melb
r33 auto gear box nothing wrong with it and it has done 130xxx $90 bucks
R33 manual box All looks good inside just 3rd gear selector clip has broken
easy fix for some people but i just dont have the tools :) $280
r33 fenders s1 Rig and left not dints or anything but a little bit of paint fade $30 bucks a side
r33 rear bumper Std and in white small scratches could do with a tutch up $35
R33 oem clutch looks like it still has HEAPS left on it CHEAP!!! $25
R33 Tail lights in ok nick $40 bucks for BOTH
R33 s2 rear pods One has a crack in it that has been glued up ( needs paint) $ 25
5 x 114.3 20mm spacers comes with nuts $80 for the pair
S14 Boot with 2 with wing Bit of paint fade on it $30
s14 drvers door without buttons bit of paint fade but somes with motor $40
and glass and all that
Sr20 Exshaust manifold Stainless steel gave me and extra 10kw's ONLY $80
intercoolers ------
Sr20 Trust straight though inter cooler a oldie but a GOODIE comes with $270
piping and silicone
Sr20 Greedy Return style cooler ( comes with piping $250
Hybrid intercooler ( no piping ) $80
Sr20 Std injectors from a s14 only done 110xxx $60
i can get photo's by request otherwise when i have time some will be up on here
0430106414
[email protected]
ok guys things are going fast
Manuel box GONE
tail lights GONE
Fender's Waiting to be picked up
and hese some pics
Return flo ( greddy ) and the straight thorough ( trust ) coolers Both come with all piping and silicone hoses
post-63394-0-04786000-1323650936_thumb.jpg post-63394-0-43597000-1323650941_thumb.jpg
I also have this exhaust tip only ever used to test once does give off that pig pipe noise and i only WANT 75 bucks for it
Pipes are 470 cm an the whole thing is about 10 cm longer
hey mate are you sure the pipes it self are 470cm thats way too long mate. 10cm the whole things is this right??/
just want to change my cannon tips to that pipes
Edited by Dbeast
Hers pics of spacers
( And you are Quite right i had a small typo what i ment to say is 450mm not cm )
That one in the photo is smaller aswell
But i d have these ones i have posted a pic of the size along with a pic of the pipes
And here is an example of what i mean about the size
Edited by Abe2
smoe one rabbed that up within 2 days :) but i can stick a flange on the back of one of these though :) these tend to look and sound alot better also :)
sold the other one so cheap because
it was the first one i ever made
still the same prize $75??? with the flange thats fit r34 gtt
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
