Hi all my car stolen from merrimac on the G.C about hour ago went outside to see it gone then hear it fire up down the street and tear off .... gutted.....
im insured but probably wont get what its worth.
definetly have a sour taste in my mouth. as much as i love my car i hope you wankers crash and die, f**king scum.
Edited by Smoker
https://www.sau.com.au/forums/topic/385179-stolen-r33-gtst/
It can be done. Chris Rodgers from Audio Express ran a demonstration night recently (and has another one coming up soon, check the events section) and he managed to get a car started and moving in about 90 seconds while the alarm/imobiliser was active and he was talking to a mate on the phone. The quality of the instalation is what makes the most difference in how secure a car can be.
https://www.sau.com.au/forums/topic/385179-stolen-r33-gtst/#findComment-6144178
how they steal it with alarm/ immobiliser.......BASTARDS
VERY easily.
shame you are not in brissy - I could use a few more R34 bits :P
I have a club exec looking over his shoulder now after I hot wired his and tossed it into reverse. he wasnt expecting it either as he was talking to someone else and the look I am told it 'WTF just happened my car just moved and I'm not in it.'
if I was anyone else I would have taken a R32 GTR for a thrash and stripped the sh1t out of it on once I got bored..
fairly fresh rego on teh 33 as well by the look of it.
https://www.sau.com.au/forums/topic/385179-stolen-r33-gtst/#findComment-6145142
  • 2 months later...
Hi fellas just thought I'd update you guys got a call from coomera CIB apparently they caught the f**kwit/f**kwits that stole my car. Though the car hasn't been recovered as he reckons it "broke down" on the highway and a mate picked him up..... They caught him for other stolen cars apparently and he just fessed up to stealing my car? Anyway that's one lessthief out there,although for how long?..... Ps well done to police my opinion of them has slightly improved...
https://www.sau.com.au/forums/topic/385179-stolen-r33-gtst/#findComment-6258128
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
