Roy, Range rovers never had 8 piston calipers from factory... 6 piston max.
Front brakes off Audi RS4 B7, RS5, RS6 C5, R8 and Gallardo are identical. They are equipped with Brembo G-family 8 piston calipers, take 4 pads per caliper and have (28+32)x4 mm pistons, which gives total piston area of 56.8 sq.cm., slightly larger than 55.54sq.cm commonly used B-family 4 piston brembos with (40+44)x2 pistons. Intended to run on 360 to 380mm rotor 32 to 34mm thick and swept pad height of 61.5 mm (tall pad). So other than some difficulties with availability of wide annulus rotors it's gonna be fine.
The G Family of calipers do come in a range of applications and I can promise you that Brembo sell a Range Rover kit. They are not factory but if you check the Brembo GT catalogue you will see that Brembo list a Range Rover kit and other giants like F150s and whatever those Cadillac SUVs that all the bling brigade drive (Escalades?) Who knows what year models it was for. I almost bought a Range Rover kit a while back but the piston info they provided me turned me off. But they were dirt cheap
I am in country NSW with work so dont have access to my drive of catalogues and caliper part numbers. I could be wrong but if you look here ... http://www.racetechnologies.com/images/Retail_GT_Application_List_2011_(06.29.11).pdf
There are a number of different G family kits. Apologies if I am wrong but the following G kits are different by part number and in turn piston sizes.
Range Rover_____1G2.9006A
LS430__________1G2.9019A
AMG CL55______1G2.9023A
ML550__________1G2.9029A
Cayenne________1G2.9016A
You may be right about the RS4/RS5/Gallardo having the same kit number. I have a quick look on the net to see catalogues but cant find the US site that has the comprehensive logs but I think you will find the 06A, 19A, 23A, 29A, 16A etc are all the exact same kit other than the piston sizes and leading/trailing applications. If you look at what part number is cast into your calipers you will be able to see what car Brembo offer that kit for and trace it through to piston sizes
What are the piston diameters like on your Stoptechs Troy and how are they handling the track work you've put them through?
My Stoptech as the same size as Brembo F40s which are the same as std R33/34 GTR Brembos at 44/38mm. They are working only ok as I have run too racey a pad comound (endurance spec PFC06) and need to get the rotors ground to get rid of the old pad material as the new pads wont bed and i am getting uneven pad deposits
I thought that a number of runs with the new pads would clean up the rotor?!?!? Not sure, have not had this problem before. It could be a simple case that I have gone from too race a pad which would glaze over because it never got up to temp...to too much a road pad that doesnt like the heat of the track. The lil RB74 is a pretty basic pad and when i pulled them out to de-glaze them by rubbing on concrete and see that the pad material is already cracking :(
So, will just stop being a tight ass and get some pagids
I thought the theory was that track pads running under temperature were in "abrasive" mode, so they wouldn't lay down any material (they just chew out the rotor)? And as a side effect clean off any material left behind by other pads.
FWIW I'm going to try A1RMs ($180) in the G4s at Wakie on saturday. Was happy with the EBC golds, but they're more like $300 (which is still cheap).
Roy, I apologize, I thought you were talking OEM calipers there...
That varying part in brembo p/n is "kit progressive number" as per brembo p/n reading key. Since it's a kit, this "progressive number" probably varies because of different caliper brackets required for different cars. But I agree, it could also mean different piston diameters.
I was writing about OEM audi/lambo caliper, which is a classic G-family caliper and has 28 and 32mm pistons. AMG 8 piston caliper (w211 E55, w220 S600, etc) is some kind of modified G-family caliper and has different piston diameters, four of them are 30mm, the other four I'm having hard time finding info about. But all the info I've seen so far suggests that brembo 8 piston calipers have a combination of 28, 30 or 32mm pistons.
The easiest and most reliable method of telling brembo piston diameter I've discovered so far (for street calipers at least) is by reading dust boot p/n. But have never seen 46 or 48 mm brembo pistons, so have no idea what are dust boots' p/n's for those.
Also sorry fot thread jacking, my p/n interface here refuses to work for whatever reason.
What are people's opinions about PFC 01 compound for mixed street/track duty? Too racey a pad, just like PFC 06 or a bit more street friendly? What about their Z-rated compound for street?
MrStabby, what do you mean by EBC gold - is it EBC yellow or EBC orange? Keen to hear your feedback about them on track and street.
Its good info , so post away!
I really want to like the PFC06. They are mega bitey but do give a great pedal feel. Its just I dont have ABS.
I used a set of PFC01s in an old F40 setup and I liked them...PFC06 are meant to be similar to PFC01 but an endurance pad. So they may be more suitable if I was running a bigger GTR booster and smaller 324mm rotor. But on my setup they mean way too many brake lock ups. Hence my move to a low friction RB74. I can really jump on the pedal and get good modulation.
I really want to find a cheap pad that works well with 343mm rotor and 4 pot caliper. Dont want to be paying $600 for pad
I faced that problem before - changed pads from TRW/Lucas to some other pad, don't remember which one exactly. Turned out the new pad material that was supposed to form transfer layer on rotors was just incompatimbe with the material that had been previously laid by Lucas pads - new pads wouldn't make new layer no matter how long I tried to bed them in. Later I read about similar issue in internet and found out that due to incompatibility of pad material there's no chance of making them work without rotor grinding or sanding. I CBF sanding rotors myself back then, so just had them regroung by a workshop.
If i'm not mistaken it is Stoptech who recommends Hawk 9012 compound for on-car rotor grinding. Maybe that's the go, but paying full race pad price just for occasional ridding the rotors of old pad material doesn't sound like well spent money to me.
BMW guys suggest swapping both pads AND rotors that were bedded in together before a track day. This solution allows some savings of not only race pads, bit also expensive 2-piece floating rotors. Plain cast-iron rotors and sporty pads for street, race pads and floating rotors for track.
With small diameter BMC, no ABS and relatively large rotors looks like you need a pad with moderate coefficient of friction and good low-temp performance.
Maybe something from EBC range would be ok, like yellowstuff. They are not super-dooper pad, but supposed to be inexpensive. But they really tend to wear out fast.
Or maybe PFC Z-rated pads (has .10 at the end of pad p/n) - no issues with material incompatibility and good cold friction u's.
Sorry yellows. Track, no problems, will buy them again if the A1RMs aren't as good. As you'd expect they don't have much bite on the street, they're usable but feel crappy. Also they seem quite gentle on rotors at street temps, unlike DS3000s which seem to chew rotors at street temps. Pad life has been fine.
for everyone's info.
w204 C63 AMG,
6 pot front brembo N-family caliper, wide annulus pad, trailing, intended to sit over 360x36mm rotor, piston sizes (34+36+38)x2 mm,
4 pot rear brembo, looks somewhat similar to P-family caliper but takes pad of different shape, trailing, rides on 330x26mm rotor, piston sizes (28+30)x2 mm
Forgot to add - they are monobloc calipers. Piston area of the front caliper is huge - 61.2 sq. cm. and might work okay on skylines only with 1 1/16" BMC.
Rear pad has dimensions similar to brembo A/C/F family pad.
Does anybody know if there's such thing as 1 1/8 BMC" on a nissan?
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
