Roy, Range rovers never had 8 piston calipers from factory... 6 piston max.
Front brakes off Audi RS4 B7, RS5, RS6 C5, R8 and Gallardo are identical. They are equipped with Brembo G-family 8 piston calipers, take 4 pads per caliper and have (28+32)x4 mm pistons, which gives total piston area of 56.8 sq.cm., slightly larger than 55.54sq.cm commonly used B-family 4 piston brembos with (40+44)x2 pistons. Intended to run on 360 to 380mm rotor 32 to 34mm thick and swept pad height of 61.5 mm (tall pad). So other than some difficulties with availability of wide annulus rotors it's gonna be fine.
The G Family of calipers do come in a range of applications and I can promise you that Brembo sell a Range Rover kit. They are not factory but if you check the Brembo GT catalogue you will see that Brembo list a Range Rover kit and other giants like F150s and whatever those Cadillac SUVs that all the bling brigade drive (Escalades?) Who knows what year models it was for. I almost bought a Range Rover kit a while back but the piston info they provided me turned me off. But they were dirt cheap
I am in country NSW with work so dont have access to my drive of catalogues and caliper part numbers. I could be wrong but if you look here ... http://www.racetechnologies.com/images/Retail_GT_Application_List_2011_(06.29.11).pdf
There are a number of different G family kits. Apologies if I am wrong but the following G kits are different by part number and in turn piston sizes.
Range Rover_____1G2.9006A
LS430__________1G2.9019A
AMG CL55______1G2.9023A
ML550__________1G2.9029A
Cayenne________1G2.9016A
You may be right about the RS4/RS5/Gallardo having the same kit number. I have a quick look on the net to see catalogues but cant find the US site that has the comprehensive logs but I think you will find the 06A, 19A, 23A, 29A, 16A etc are all the exact same kit other than the piston sizes and leading/trailing applications. If you look at what part number is cast into your calipers you will be able to see what car Brembo offer that kit for and trace it through to piston sizes
What are the piston diameters like on your Stoptechs Troy and how are they handling the track work you've put them through?
My Stoptech as the same size as Brembo F40s which are the same as std R33/34 GTR Brembos at 44/38mm. They are working only ok as I have run too racey a pad comound (endurance spec PFC06) and need to get the rotors ground to get rid of the old pad material as the new pads wont bed and i am getting uneven pad deposits
I thought that a number of runs with the new pads would clean up the rotor?!?!? Not sure, have not had this problem before. It could be a simple case that I have gone from too race a pad which would glaze over because it never got up to temp...to too much a road pad that doesnt like the heat of the track. The lil RB74 is a pretty basic pad and when i pulled them out to de-glaze them by rubbing on concrete and see that the pad material is already cracking :(
So, will just stop being a tight ass and get some pagids
I thought the theory was that track pads running under temperature were in "abrasive" mode, so they wouldn't lay down any material (they just chew out the rotor)? And as a side effect clean off any material left behind by other pads.
FWIW I'm going to try A1RMs ($180) in the G4s at Wakie on saturday. Was happy with the EBC golds, but they're more like $300 (which is still cheap).
Roy, I apologize, I thought you were talking OEM calipers there...
That varying part in brembo p/n is "kit progressive number" as per brembo p/n reading key. Since it's a kit, this "progressive number" probably varies because of different caliper brackets required for different cars. But I agree, it could also mean different piston diameters.
I was writing about OEM audi/lambo caliper, which is a classic G-family caliper and has 28 and 32mm pistons. AMG 8 piston caliper (w211 E55, w220 S600, etc) is some kind of modified G-family caliper and has different piston diameters, four of them are 30mm, the other four I'm having hard time finding info about. But all the info I've seen so far suggests that brembo 8 piston calipers have a combination of 28, 30 or 32mm pistons.
The easiest and most reliable method of telling brembo piston diameter I've discovered so far (for street calipers at least) is by reading dust boot p/n. But have never seen 46 or 48 mm brembo pistons, so have no idea what are dust boots' p/n's for those.
Also sorry fot thread jacking, my p/n interface here refuses to work for whatever reason.
What are people's opinions about PFC 01 compound for mixed street/track duty? Too racey a pad, just like PFC 06 or a bit more street friendly? What about their Z-rated compound for street?
MrStabby, what do you mean by EBC gold - is it EBC yellow or EBC orange? Keen to hear your feedback about them on track and street.
Its good info , so post away!
I really want to like the PFC06. They are mega bitey but do give a great pedal feel. Its just I dont have ABS.
I used a set of PFC01s in an old F40 setup and I liked them...PFC06 are meant to be similar to PFC01 but an endurance pad. So they may be more suitable if I was running a bigger GTR booster and smaller 324mm rotor. But on my setup they mean way too many brake lock ups. Hence my move to a low friction RB74. I can really jump on the pedal and get good modulation.
I really want to find a cheap pad that works well with 343mm rotor and 4 pot caliper. Dont want to be paying $600 for pad
I faced that problem before - changed pads from TRW/Lucas to some other pad, don't remember which one exactly. Turned out the new pad material that was supposed to form transfer layer on rotors was just incompatimbe with the material that had been previously laid by Lucas pads - new pads wouldn't make new layer no matter how long I tried to bed them in. Later I read about similar issue in internet and found out that due to incompatibility of pad material there's no chance of making them work without rotor grinding or sanding. I CBF sanding rotors myself back then, so just had them regroung by a workshop.
If i'm not mistaken it is Stoptech who recommends Hawk 9012 compound for on-car rotor grinding. Maybe that's the go, but paying full race pad price just for occasional ridding the rotors of old pad material doesn't sound like well spent money to me.
BMW guys suggest swapping both pads AND rotors that were bedded in together before a track day. This solution allows some savings of not only race pads, bit also expensive 2-piece floating rotors. Plain cast-iron rotors and sporty pads for street, race pads and floating rotors for track.
With small diameter BMC, no ABS and relatively large rotors looks like you need a pad with moderate coefficient of friction and good low-temp performance.
Maybe something from EBC range would be ok, like yellowstuff. They are not super-dooper pad, but supposed to be inexpensive. But they really tend to wear out fast.
Or maybe PFC Z-rated pads (has .10 at the end of pad p/n) - no issues with material incompatibility and good cold friction u's.
Sorry yellows. Track, no problems, will buy them again if the A1RMs aren't as good. As you'd expect they don't have much bite on the street, they're usable but feel crappy. Also they seem quite gentle on rotors at street temps, unlike DS3000s which seem to chew rotors at street temps. Pad life has been fine.
for everyone's info.
w204 C63 AMG,
6 pot front brembo N-family caliper, wide annulus pad, trailing, intended to sit over 360x36mm rotor, piston sizes (34+36+38)x2 mm,
4 pot rear brembo, looks somewhat similar to P-family caliper but takes pad of different shape, trailing, rides on 330x26mm rotor, piston sizes (28+30)x2 mm
Forgot to add - they are monobloc calipers. Piston area of the front caliper is huge - 61.2 sq. cm. and might work okay on skylines only with 1 1/16" BMC.
Rear pad has dimensions similar to brembo A/C/F family pad.
Does anybody know if there's such thing as 1 1/8 BMC" on a nissan?
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
