  • Replies 46
Posted Images
read somewhere close to 320hp at the wheels
officially 280hp
R34 GTR in standard form is pretty slow and very laggy to my liking
which is why no keeps them stock
Wait what?
280hp at fly but yeah around 320 at fly, around 230-250 at wheels if totally standard.
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6144241
Stock Standard R34 GTR's have been proven on many different occassions to make around the 320 all-wheel horsepower mark. Nissan quoted them as 206kw due the "gentleman's agreement" but in reality they made about ~50-60 more hp than quoted.
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6144591
Flywheel horsepower. Not wheels.
Show me one stock standard R34 GTR making 320awhp.
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6144615
This dyno sheet is of my car with and without the intake snorkle removed. Car was bone stock, down to intake and exhaust but had it's boost restrictor removed.
So in regards to the OP's question, on a stock standard GTR with snorkel and boost restrictor still in place, I'd have to disagree here mate and say that 320AWHP would a very optimistic figure. pinch.gif
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6144683
Looks around about 270awhp / 201awkw with the snorkel in place. Agreed, 320 is rather optimistic to say the least.
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6144766
Mine ran around 12.5-13 PSI with restrictor removed, so yeah around 1 bar.
It would depend on flow of air filter/exhaust etc. So anywhere between 12psi to 15psi. Hence why it's always a good idea to get the AFR's checked when you remove it.
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6145334
I've seen it on a Nissan Skyline documentary. It showed a bayside blue R34 GTR non-v-spec on a dyno and it made between 310-320awhp. I can't remember to exact figure; I watched this doco a long time ago =\
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6146135
Was this "documentary" hosted by Ketzal Sterling? :whistling:
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6146237
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
