Hi there,
I have a few questions about the mirrors on my V35.
1. First up the glass on the drivers side needs replacing as it looks like it is worn & the mirror glass has worn away. Where can I find a replacement? I saw some for a G35 on eBay but I am not sure if they will fit.
2. I read about an option where the mirrors will drop down when reversing. Is there a kit that I can get that will do this?
3. Auto folding mirrors. Not that bothered about this option but I was wondering if there is an option to make the mirrors fold inwards when the cars is parked?
4. My mirrors seem to be loose, not sure if they need to be adjusted somehow but I tried to tighten them up with no luck. Must be a simple fix but hey while I am on the subject of mirrors why not ask!
5. I am also not sure if the mirrors are broken somehow as they are loose & I don't think that they are working properly. If not what are my options to replace them?
https://www.sau.com.au/forums/topic/385339-mirrors/
Yes I have a coupe. The ones that I have seen for a G35 have the writing on the mirrors. Not overly expensive but I prefer not to have the writing. Any suggestions...
Is the writing etched on? I've only ever seen cheap cars with a sticker - easily removed.
BTW, how'd your car go today with the cruise install?
https://www.sau.com.au/forums/topic/385339-mirrors/#findComment-6151116
    • Today, I'm a Breville BES920 tech, new triac board and new 3x way solenoid. Had overheating issues, home RCD tripping when it got warm, and the boiler stayed on when the machine was shut off. Also, usually 3x way solenoid chatter, this is the 3rd time I'm replacing it. Mind you, this machine is 9 year old and send it every day doing at minimum 3x double shots. When the in laws come over to took after my daughter, it will easily see 6x double shots in a single day. Tried to be somewhat compliant, crimped and then used a screw connector over the top. Would have preferred to use heat shrinks.   After all that, turns out all the overheating has damaged the o-rings to the steam tap as well. Ordered new ones, coming soon.
    • Still got it- First time checking sau in a while ahhaha
    • I don't know about that. I can hoon my R32 around - hard launches, high lateral Gs - with <<1/4 tank without any such shenanigans. This with the previous 040 and the current GSS342. I would suspect a fuel line problem. One of the hoses associated with the top of the tank perhaps.
    • This is amazing. Love that you’re giving the boys an intro to cars and off the screens. They probably have an insta for the car and build posts on TikTok for their mates.
    • It is.  Your car works fine with the tank full. If you drive like a Nana it works fine.  You give it a boot full with half a fuel tank, you get surge.  It 100% is a fuel surge issue. Maybe have a look at installing a Hydramat if you don't want to install a surge tank.  https://www.holley.com/products/fuel_systems/hydramat/
