hey peeps have a r34 (op6) hi flow turbo done by gcg
is in good condition (very little shaft play) is currently on car making 276rwkw with suporting mods
had it for year and a half
reason for sale is im going 3037
selling for $1200 and thats for turbo, split dump, and 3 inch dump to cat (brought for $1950)
as i said is still on car so if local can come see what its like in car other wise will remove when sold
car is not my daily so can remove over night
im located in traralgon vic 3844, 1.5 hour drive east of melb
will post at buyers expense
msg or call me on 0433167726
cheers jade
https://www.sau.com.au/forums/topic/385890-gcg-34-hi-flow/
standerd engine, sard 550 injectors, walbro in tank pump, super spark coils, plazmaman pro seris cooler,3inch zorst with decat no mufflers just the cannon at rear, power fc, tuned at created motor sports
https://www.sau.com.au/forums/topic/385890-gcg-34-hi-flow/#findComment-6155733
What boost and other mods does it have to get 280? I thought GCG ones were normally for up to 230-240?
You'll see this power figure with a R33 hiflow, you get more out of a R34 highflow.
You will normally see between 260 to 280kw depending on the dyno.
https://www.sau.com.au/forums/topic/385890-gcg-34-hi-flow/#findComment-6156382
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
