not that I know of.
hi,
because i need a new engine and i don't know if my engine is a s1 or s2. its a 95 model and i have been told it is a series 1.5. i jsut came back from the mechanics and
they have taken the head out and i need some help.. It doesnt have airbags..
Also there is NO 1.5. Its either a series 1 or 2. When I worked in a Jap parts shop we always had people saying they had a 1.5 and the Jap manager always said "whats a 1.5?, there isn't one"
Its just a series 1 running a s2 engine during the series change over, they never called it a 1.5.
Sorry to babble on this but it always p*ssed me off when people said it.
saying s1.5 is the easiest way to clarify things. yes it is techincally a series 1, but when it is running a s2 engine, wing and a few other minor differences, it can be vital for noobs to say that they have a s1.5 at times. for example if they say that they need new coils and want to know what part number they need for splitfires. if they simply say that they have a series 1 then they will get told the wrong information.
yes, s1 has a green sticker on the AFM from memory
Correct.
Shut up. There is also Series 2.5 Technically.
This.
What if you went to Nissan and said you had a 1.5? They wouldnt know what your on about.
Well they can get f**ked because i wouldn't want coil packs for a Series 1 would i? nor AFM?
so i have a series 2 engine.. just didn't want to buy the wrong engine.
thanx
Sounds like it. But i was under the impression all S1.5 had Airbags. hmm.
None the less, if it doesnt utilize a standalone Ignitor and has a Pink AFM i daresay its a Series 2 engine.
S1 has the ignitor on the rear of the engine S2 does not.
you should be able to determine what you have by the plugs anyway.
also there is a S3 version of it as well. mechanically not a lot changes - electrically though its different,
slippy,
whilst I agree with you I too reference them by 1,1.5,2,3 as it is easier to talk to the customer with those numbers, when talking to nissan though I reference by chassis number and model. its easier when dealing with O/seas suppliers to give correct info than to half ass it.
slippy,
I consider it to be Series 2.5 and not 3 as like you said it only has minor changes. As a series 2 engine and some series 2 bits made a series 1 a 1.5, a few changes to a series 2 engine should signify Series 2.5.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
