Fairly sure its just the red stick which sits on the ECU kick panel. When I was in the market for a R33, I found 4 cars which had these, almost convinced me to buy the car lol just to say Ive got a flare!
Yeah guys its just a red flare :)
$100 bucks because all the others that have been for sale have been around that.
Anyone who wants pictures just pm me your mob number and I will send one or two through :)
screw you guys! i had like 8 of those when i went to the wreckers and took them out of the half cuts!!! i used them all for some fun. i could have been 800 bucks richer!!!!!!!
I don't understand why they cost that much when you can buy a survival kit for much less and the flare is included :/
I really wouldn't pay $100 for it. I'd give like... $30 max. They really aren't that rare. It depends on who imports the car and what their standard is on getting it complied etc. Alot of the privately imported skylines Ive seen have the flare, while the more commercial ones(a few of the dealers for import cars) NEVER have the flare. Its not the flare that shoots into the air either. Its the flare which just glows red at the end in your hand so if you have been driving on the mountains of japan and happen to fall off a cliff face on a snowy day, you can use it to signal searchers.
  • 3 weeks later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
