  • Replies 58
Whats the problem with the auto?
They are just as strong as the manuals, and with a bit of work will always get you down the 1/4 quicker than a manual. I admit the standard autos (even with mods) they are not the best for serious track work, but if manuals are so bad, why have the F1 teams oll gone this way?
The other advantage is that with a properly matched torque converter you can install the biggest lagy turbo (with huge RWKW) and still come on boost quickly.
I dont have any objection to a manual, but I dont understand the rush many people are in to change from the auto.
Any of you guys after side skirts for the R32 4 Door? I've got a pair in good condition primed already and will paint it to gun metal grey if desired. They fit the coupe as well but they look much better on the sedan. I'm looking at around $150 for the pair. PM Me.
Here's mine.
I have the tiptronic auto and I've been out to the track with it. It's great fun and I get the bonus of ease of driving in traffic which in Sydney sucks arse.
My lights are different to the 2 doors as well but I think they are actually better.
i spose the auto would work a bit better with higher static compression & 1/2 a litre more capacity than it would on my little RB20. I guess it comes down to personal choice. I'm an ex country lad who has only ever owned manuals. one day it might change
how much are those impul 4drs worth these days?
if only i could get a 33 4 door gtr................anyone sellin one
That would be nice... They sell for a mint on the extremely rare occassion that they're found by an Aussie importer.
Even better would be an R32 GTB-4 - but only 5 were made AFAIK. They looked just like R324D's car, but with the fat guards on the front AND back, as well as the RB26DETT, of course. Hell, I'd even settle for the Autech R-32 with the atmo RB26DE (still had individual throttle bodies, etc.) Mmmmmmmmm.
BTW, R324D, I'm sure I saw your car a few years back waiting to turn right (North) onto Silverwater Rd a few years back. I 'd just turned left 'cos I was on the way to AutoSalon (maybe two years ago?) and spotted your car wating at the intersection, then I did a double-take when I realised it was a Sedan/4-door/coupe-with-practicality/(insert bodystyle description of choice)...
Nnnniiiiiiiiiicccccceeeee! :(
Nick T
hmm Danny from Autotrust is also the proud owner of an IMPUL R33R down here in melbourne. Your cars look like long lost twins.
and rjay... dude... woah lots of red... what seats do you have?
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
