Im not sure about everyone
but there is something on the road that is starting to really damn annoy me and it must stop
Ill set the scene , I was lying on my couch today half asleep enjoying one of my last days of holidays. The sun was out the birds were making peaceful noises, I had a ice cold bourbon at my side and was in heaven
I then got a very rude awakening by a high pitched dull monotonous tune!
YES IT WAS THE evil mr whippy , for the Fifth FUc*ing time this week!
driving slowly up and down my street in a 1950's ice cream truck painted pink!
Does anyone else have to contend with this sort of menace, what do you suggest I should do , take out a restraining order against mr whippy???
your advice would be appreciated
https://www.sau.com.au/forums/topic/38655-a-new-menace-on-the-road/
i love the sound of Mr Whippy coming down the street reminds me of being a kid again ...... when i was little i used to get so excited over that sound and started concoting ideas about how to get $2 for an icecream out of my folks.
Nah sorry VOTE ONE WHIPPY!!!
LOL - this brings back memories of the Simpsons episode where Homer's goal in life is to be 300lb so he can work from home... At the end of the episode, Homer steals a ice cream van and drives it to the power plant to save the reactor.
Anyway, after he drives through the fence, all the staff jump on the ice cream van and try to order ice creams.. LOL
Anyway, you have to be there,
J
P.S. Isn't it funny how there's a Simpson's episode for every 'moment' in life :)
I went to the danny green boxng fight at couple of weeks back and when singing the national anthem it had more of a dance tune background music...
I'm thinking lets make a mr whippy drum N Bass remix or break beats remix of it.. with a few vocals...
"Put your hands up in the air, put your hands up in the air......"
Don't worry about the music comin out of his speaker worry about the sad arse engine that sucker is running.
If I were you id run out there and give him the low down on how to strap a bug mutha RB26DETT to that sucker, chuck on some nitto 555r's and rock that baby down the motorplex!!!!!!!!
Ohh yeah grab one of those sundae thingo's in the cup he sells, they taste mad!!!
lol
how bout "Put your hands up in the air.............if you want ice cream, Put your hands up in the air..............if you want ice cream"
the mr whippy song is called Greensleeves...... Dan I would buy a break-beats mix of that hahahaha
Whenever i hear the ice cream I think of Eddie Murphy in Delerious - ICCEEECREEAAMMM THE ICECREAM MAN IS COOOOMMMMMING. I've got an icecream and you cant have none, cause your dads an alcoholic and your on the welfare.... you cant afford it, you cant afford it. :)
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
